      06-29-2023, 03:45 PM   #1
phan
Drives: X5 35d, M5 SC'd, M6GC
"Twitchy" Rear End?
Lately, I've noticed somewhat of a twitchy feeling coming from the rear when hitting a mild bump or road imperfection on the freeway/at-speed. It's not bouncy so much, just...twitchy? Though not as extreme, the feeling is exactly like when I needed to replace my upper control arm bushings on an old e36 m3 I used to own. I'm assuming it's something comparable, bushings needing replacing. Has anyone experienced (and fixed) anything similar? The car has 67k on it if that helps at all.
Thanks!
vSook37.00
      06-29-2023, 11:30 PM   #2
vSook
vSook's Avatar
Drives: F13 M6
Same.. for me it’s because my wheel bearing & hub need replacing. Bolts broke inside and wheel seems a bit loose
      06-30-2023, 12:37 AM   #3
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
Check all the rear subframe suspension bushings and check the shocks as well.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      06-30-2023, 10:53 AM   #4
phan
interesting. i'll finally have a little time to jack the car up this weekend, i'll check the wheels themselves to see if they're loose at all.
thanks, i'll definitely get the car in the air and check at some point this weekend.
i guess i'd asked more to see if it were a common thing like what i'd experienced with my e36 m3.
      06-30-2023, 08:11 PM   #5
arucano
arucano's Avatar
The M6 has less rubber bushings than the E36. Subframe to body is a hard mount, so the suspension (arms) bushings are the likely cause of a loose feel in the rear end. Week or leaking shocks can also give a loose feel. Check the shocks for leaks along the rod seal.
