05-03-2014, 01:56 PM | #23 | |
Rep 715
Also, who's going to do your coding? Thanks |
05-03-2014, 11:19 PM | #24 | |
Rep 295
Drives: '14 640i GC
ordered from FCPEuro (got redirected to their website from ETK). The controller was $600 and the touch countrol unit was $60. I installed and coded myself today...took me about 2 hours being extra careful removing the center console trim. works perfectly! |
05-04-2014, 07:17 AM | #25 | |
Rep 715
Congrads - nice job installing yourself. Not sure I would be that adventurous. 2 questions - Did you get the ceramic version, and could you please give me the BMW part numbers so I can be sure I order the right ones. Thanks again. |
05-04-2014, 10:36 PM | #26 | |
Rep 295
Drives: '14 640i GC
I did get the ceramic version and here are the part numbers: Idrive controller touch: 65829327170 Controller touch control unit: 65829338800 The touch controller still does not appear under the 6 series diagrams (or was not there a week ago) so I took the part number from the F10... the idrive controllers are the same. Good luck if you decide to go with it and let me know if any doubts. Here's a picture of the final product |
05-05-2014, 09:28 AM | #27 | |
Rep 715
Terrific job. See your in S. Florida- I am in Gainesville. Would love to pay you to do it for me if we were closer! How big a job was it to swap controllers - how much trim did you have to remove? And where did you get the coding info? I had remote coding done last month, but don't think the gentleman had the code for the touch controller. Joe |
05-05-2014, 08:21 PM | #28 |
Rep 295
Drives: '14 640i GC
I don't think it's a too much of a big job; the hardest part is maybe the wiring: you have to connect the touch control unit to the touch controller wiring. In my case luckily I always save whatever spares remain after I finish a job so I had a connector that fit perfectly on the control unit and just had to tap the wires to the controller's end; otherwise some welding would be needed.
Then to access the controller you need to remove 4 panels (2 on each side), the wood trim that surrounds the gear shifter and finally the leather-trimmed piece that houses the controller. Codingwise you need to change 4 values; those are available on "the other forum"...I saw you posted there today, it's at the beginning of that same thread. credit to Milkyway! Last edited by DR1er; 05-06-2014 at 09:16 AM.. |
05-07-2014, 08:55 PM | #29 | |
Rep 846
I almost forget how to type address in the idrive now.
2012 X6 35I (Gone) 2013 650 GC (Gone)
2014 M5 Comp PKG (Gone) 2015 X6 50I (Gone) 2017 M3 Comp PKG 2017 MINI JCW 991.2 GT3 (coming) |
09-26-2016, 07:33 AM | #30 |
Rep 2
I'm a great fan of such sites about cars! http://skywritingservice.com/blog/30...ore-successful has some tips of successfulness!
09-27-2016, 05:13 AM | #31 | |
Rep 1,235
I've done this retrofit and it is excellent. If anyone in the UK needs help getting this done, shoot me a pm |
02-10-2017, 10:07 PM | #32 |
Rep 72
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
Garage List 2021 BMW X6 M50 [0.00]
2018 Porsche 911 GT3 [0.00] 2015 BMW i8 [0.00] 2008 BMW M Coupe [0.00] 2017 Porsche 911 Tu ... [0.00] 1986 Porsche 911 Sl ... [0.00] 2021 BMW Alpina XB7 [0.00] |
anyone have any instructions for removing the trim pieces to get access? And specifically what pieces need to be removed to get access?
02-13-2017, 07:31 AM | #33 |
Rep 209
Have a look at this post - it gives you all the information you need to remove the trim to get to the i-drive controller:
http://www.6post.com/forums/showthread.php?t=1081541 |
04-10-2017, 12:50 AM | #34 |
Rep 40
Upgrade completed!
With the help of the above post to be able to install the controller without breaking anything when removing the trim off the console, I was able to install and code in less than an hour. Half of that time went into trying to recover a dropped screw near the gear shifter.
Used controller from eBay (ceramic) $180 Module from ECS tuning (bought the Mini one, it's $15 cheaper, same part) $70 "Y" cable from eBay (shipped from China) $18 Coded myself Total cost lessthan $300. Nice to have, not absolutely necessary but way cool. Anyone looking into doing this, it's is relatively easy. Cheers.
'76 2002 M42/5spd Swap - Daily Money Pit
'06 Aston Martin V8 Vantage 6spd - Garage Queen '14 BMW 640i M Sport - Date Night Transport '15 VW Touareg V6 Executive - Daily Driver |
07-09-2017, 04:48 AM | #35 | |
Rep 135
A) realoem and other sites states that the i-drive controller is not compatible with my car, is this true? B) I'm guessing I'd need the idrive controller, the touch module and the 'Y' cable Alongside coding to get it work? These are the bits I'm looking to purchase; https://www.ebay.co.uk/itm/172767038441 https://www.ebay.co.uk/itm/262865192798 https://www.ebay.co.uk/itm/201967804693 Would I need anything else to get this touch controller fitted and working (apart from the coding) Could somebody also shed some light on the coding side, complete newbie to coding, have brought the neccessary enet cable and installed e-sys; and that's it. Many thanks |
07-09-2017, 09:56 AM | #36 |
Rep 40
A) It will show as non-fitting because that year the touch controller was not available on the 6er.
B) yes, those 3 items are the correct ones. Coding can be found on the other forum, just goggle "F06 touch retrofit" it's the first result I did not do the additional CAFD and other recoding as BMWAK suggested above. Everything works, but I may have background error codes because I took my car to service and they replaced the seat belts which require a software update and they could not do it according to the service advisor because of the retrofit. Go figure. BMWAK, do you mind sharing the changes that would be needed in addition to the coding on the other forum?
07-09-2017, 11:49 AM | #37 | |
Rep 135
The links on ebay are all compatible with each other? it's a real minefield trying to find the correct touch controller. I've looked on the other site and the coding side doesnt look as straight forward as i'd hoped. Going to give it a shot though.
03-17-2018, 11:25 PM | #38 |
Rep 5,623
can the i-drive controller with touch be retrofitted on a 2013 m6? plug and play?
if so, can anyone confirm i have the correct part # from the pic below and do i need the touch control box (part #3) as well? thank you.
06-18-2018, 09:38 AM | #39 |
Rep 7,476
Based on the info given in the part database...the answer would be NO. The build date range is listed not just for the part nbr you inquired about...but for other part nbrs that were superseded. It appears the part can be used starting with some models that had a 3/2014 build date-up. If your 2013 M6 was built in March 2014-up...then it would be plug-n-play.
11-22-2018, 09:10 PM | #40 |
Rep 141
Has anyone done this recently?
06 M3 vert alpine white on cinnamon - sold
06 M3 vert alpine white on red - sold 06 M3 vert alpine white on red - sold ( my 3rd) 05 M3 coupe alpine white/ cinnamon - 18k miles! 2011 550xi alpine white on ivory (sold) 2013 640i black sapphire metallic on cinnamon 2014 Cayenne GTS |
12-12-2020, 02:07 AM | #42 |
Rep 48
Does anyone know where the touch module is located? I couldn't find it.
It works like a normal iDrive without the touch function if plugged in without the module. I am surprised is plugs in the non touch wiring. Update: I figured it out. The touch module is an add on, lol. I thought it was replacing a non touch module. Makes sense for the Y cable. Last edited by R0N; 12-12-2020 at 02:31 AM.. Reason: Corrections |
