      11-14-2017, 06:36 AM   #1
Giggs11
Giggs11's Avatar
49
Drives: 13' f13 650i xdrive,M package
Zip tie
Hi all , when you zip tie the flaps on msport exhaust do you need to unplug the back pressure hose and then plug hose with something? Tanx
      11-14-2017, 09:56 AM   #2
The0pportunist
The0pportunist's Avatar
471
Drives: F30 335i
I remember watching a video on this - hope this helps.
      11-14-2017, 11:36 AM   #3
bravo261
Drives: F06 650
not at all...just the zipties
      11-14-2017, 02:20 PM   #4
Giggs11
Giggs11's Avatar
49
Thank you guys
      11-15-2017, 02:06 AM   #5
Giggs11
Giggs11's Avatar
49
Can anyone link me a video this being done on 650
      11-15-2017, 05:52 PM   #6
BMPOWERED
BMPOWERED's Avatar
65
Drives: 2014 650 GC M sport
I don't have a video but a quick tip. Take a long object ie. a stick and push the flap open thru the exhaust pipe. As you're pushing it open, look at the valve control on top of the pipe to see how it operates when open. Leave the stick in the pipe to keep the flap wedged open. Then tie your zip tie around the valve mechanism on top of the pipe to keep it open
2014 BMW 650GC M sport
2011 BMW 550i M-sport/AW
1991 Nissan 300ZX Twin Turbo
2007 Chevrolet Corvette Z51 (sold)
2001 BMW 325ci (sold)
Giggs1148.50
      11-16-2017, 03:03 AM   #7
Giggs11
Giggs11's Avatar
49
Hey ty bmwshay , have you heard anything about doing this that Msport exhaust will lose the gurgle when you push a little harder and loosing some power 0-60 this is something I read on one of the BMW club forums , and what about the little black hose doesn't need to be disconnected from the valve itself and then plug with something like a golf....
      11-19-2017, 01:35 AM   #8
BMPOWERED
BMPOWERED's Avatar
65
I did feel like it lost a bit of the gurgle which I attributed the gurgle to the valves opening and closing, however the trade off is worth it. I've also heard the rumor that the car lost some torque at low rpm due to backpressure. I've also heard others call BS on this. I have to admit that I sort of felt like I lost a bit of low end torque and that was even before I heard others mention it. I'm not 100% sure though. If you are using the zip tie method, the hose is irrelevant...just leave it plugged in. The only time you need to plug the hose is if you actually cut off the valve/actuator (some do this to accommodate bigger tips) or if you get an aftermarket exhaust that doesn't use the vacuum valve system
      11-20-2017, 03:42 PM   #9
Spinner6996
Member
Spinner6996's Avatar
Drives: 2015 i8 Pure Impulse
Ignore the video....doesn't apply to 650 M sport. Just zip tie the actuator arms on both sides while the valve flaps are held open.
Lotus Evora S
RR Sport SVR
      11-21-2017, 12:27 PM   #10
Fkhan993
Drives: BMW 650i M-series
Hey guys! I’m new to this form, just picked up a 2014 650i M-sport Xdrive few weeks ago. Do you guys by any chance have a video of the car with zip tie? I’m curious to see what the exhaust sounds like.. also have you guys heard anything on n63intake tune? I’ve attached the link so you can see what tune I’m referring to.
https://n63intake.com/product/n63-tu-tune/
      11-21-2017, 08:19 PM   #11
Giggs11
Giggs11's Avatar
49
Nice
First time hearing about that tune ( drop in chiptung will give you same hp upgrade but not the other things they have mentioned on that website , but taking car apart and mailing it lol Neah lol
      12-03-2017, 10:27 AM   #12
AmooManiak
Drives: 21 X5 M50i -> M2C -> 21 M5C
Can someone post pictures of their zip ties method on the 650i? I understand how the mechanism works by opening it manually, but I can't think of a way to make it stay open using a zip tie...
