      12-06-2015, 04:26 PM   #1
dpharm
Drives: 2013 650i M-Sport
***!&!! - Pretty sure I just goofed up in a major way
2013 650i Coupe, with late model year N63.
Had the low coolant light on and added some distilled water / coolant mix to the cap in the attached pictures.
I searched forever for the actual coolant filler neck (not shown in the manual for the 650). I assumed that the cap pictured was where I needed to add it. Well, after I did, I just happened to look at the front (right under the plastic engine cover) and found where it really was.
So...what mayhem have I caused by adding about 0.5L of coolant to whatever is under that cap in the pictures. Sumofabitch
Edit - if it matters, cap reads "do not open when engine hot"
      12-06-2015, 09:01 PM   #2
zanye08
Drives: 2012 BMW 650I Coupe Imola Red
You are fine. At first I thought you screwed up because the N63 650 has the expansion tank before the shock tower. N63TU changed the location to behind shock tower..
      12-07-2015, 05:48 PM   #3
dpharm
Thanks for the reply. All the documentation I could find (including the manual) is pre-N63TU.
