      02-14-2016, 12:29 PM   #1
Royce Martin
Royce Martin
Royce Martin's Avatar
Drives: 2013 650i xdrive GC
Exclamation Currently running M5 wheels with 295/30-20
Hey,
I'm currently running OEM M5 wheels on my 650xi GC, I didn't run the M6 wheels because the rear's are much wider and being that the wheelbase on the 6 series is adopted from the 5 series I just went with the M5 wheels. I'm currently stacked with 295/30-20 in the rear it sticks out a little, can I go down to 285/30-20 without issue? I'm going to lower my car and the wheels are going to rub in it's current stage.
      02-14-2016, 01:37 PM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
The rear 343M (M5) rims are 10" wide so basically you can install 285mm wide tire with no issue; however compare to your OEM 650i wheels, your new rear setup still will stick out about 15 mm... 10 mm because of rim's offset (34 vs 44) and 5 mm because of tire (285 vs 275)
      02-14-2016, 02:06 PM   #3
Royce Martin
Royce Martin
I'm going to post pics so you can get a much better look.
