      02-21-2016, 01:38 PM   #1
///M5-PAV
Drives: 2013 M6 Coupe
do f10 m5 wheels fit f13 m6
i have a pair of bbs fi for my f10 that i sold now i purchased an f13 m6 i want to know will those rims fit ??? help plz
      02-21-2016, 07:54 PM   #2
GladiatorOwner
Drives: 22 M4C
No wrong off sets. "M6 Coupe" will tell you straight.
      02-21-2016, 08:01 PM   #3
ice7
ice7's Avatar
371
Drives: ///M's
2014 BMW M5 Comp  [0.00]
2015 BMW X5M  [0.00]
2022 BMW M5 CS  [0.00]
They will fit but you probably need to add 10 or 12.5mm spacers
      02-21-2016, 08:21 PM   #4
///M5-PAV
so your saying it wont fit for sure ?
      02-21-2016, 08:22 PM   #5
///M5-PAV
ive never used spacers if i put them on will it be dangerous to drive ?
      02-21-2016, 09:39 PM   #6
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Good quality spacers are perfectly safe. The fronts (if you have the FI-R 20x9.5 ET28) are ok as is. The rears (if the FI-R 20x10.5 ET28) will fit and clear the strut, but will sit further in than the OEM wheels. Will need a 10 - 15mm rear spacer for aesthetics.
      02-21-2016, 10:32 PM   #7
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
To add, we recommend a stud conversion kit instead of extended bolts when using a non bolting spacer.
      02-21-2016, 10:37 PM   #8
///M5-PAV
thank you i will look into it
      02-22-2016, 12:49 AM   #9
brad850csi
Drives: 16 F13 M6 Comp
miamiten, have you done a 20x10.5" 28mm wheel on an M6, how did it look at did it clear the inside of the body?
      02-22-2016, 01:49 AM   #10
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
I have seen that combination on F06/F12/F13 M6 as well as non M versions of the same (I'm not a tuner shop or retailer - much higher in the supply chain) Since you asked how it looked I'll answer to that aspect first.
Awful. It's very difficult to tell visually, but the distance between the wheel faces on the OEM setup is slightly wider in front than in the rear. 10.5ET28 on the rear is 9mm further inside the body and is enough to be visually displeasing.
Will they clear the strut? Yes. There is quite a bit of inner clearance even under full compression (though not near as much as a non ///M. Rear axle carrier on Fxx M5/M6 is carried over with little modification from E6x M5/M6 with shorter output shafts so the geometry is a bit different below the upper mounting points)
Would I suggest it or put it on my car? Nope. Just looks wrong.
      02-22-2016, 02:42 AM   #11
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
This very early F10 M5 Prototype is about the same visually as the 10.5ET28 appears on an M6. The camouflage panels bring the body width to within a couple of millimeters of the production M6. The front fenders are also not extended under the camouflage and approximate the front appearance as well with the camouflage panel thickness applied.
      02-22-2016, 10:39 AM   #12
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
You need to know the offset first. I assume you are talking about OEM rims' offsets (if bbs has the same offset) right? The M6 offsets for OEM 343M M6 rims are 31 front and 19 rear however for 343M M5 is 32 front and 34 rear. Having said that there is almost no difference in front end but in rear end the suspension side will not be the same and probably you need to add 10-15 mm spacer. You won't have issue at fender side BTW.
If you are talking about the custom rims then you need to make sure the offset is in range.
      02-22-2016, 10:53 AM   #13
dkuznetsov92
dkuznetsov92's Avatar
51
Drives: 2014 BMW M6 GC
Small world, I just upgraded myself from the M4
      02-22-2016, 05:33 PM   #14
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
The suspension geometry is identical between Fxx M5 and M6. Only the wheel base differs with the F12/13. The 6er body is wider at the rear by a significant amount (in reference to wheel specs), hence the lower offset for aesthetics. A 10.5 rear with a much higher offset than ET28 will still clear the strut as long as the face will clear the calipers and the tire isn't wider than a 295 width PSS3 (I have the CATIA file open in front of me). It looks worse than terrible but fits within the minimum clearance spec.
      02-22-2016, 10:45 PM   #15
///M5-PAV
the front bbs wheels are 20 x 9.5 26ET
and the rear are 20 x 10.5 28ET
i dont mind putting spacers to make it look nicer i just want to make sure they will fit being said i spend 9grand on them and just sold my m5 id like to use them on my new m6 im not good with rims and offsets and that stuff im clueless lol
      02-22-2016, 10:46 PM   #16
///M5-PAV
nice how do u like it so far ? i like the red interior i had that in my m5 now i have the silverstone interior i hope i didnt make a mistake selling my m5 for the m6 lol
      02-22-2016, 11:34 PM   #17
Powerbeast
Powerbeast's Avatar
Drives: F80 M3 RarriRot
I took off my BBS FI wheels off my 2013 F10M5 and bolted them right up to my 2015 M6GC.
      02-23-2016, 09:25 AM   #18
dkuznetsov92
51
You have one life to try them all, beauty of cars is you can get another one if its not for you. Silverstone is a pain to clean from denim transfers etc, I use to have an E93 M3 interlagos blue on bamboo, and I would be cleaning the seats day and night..
      02-23-2016, 01:20 PM   #19
brad850csi
powerbeast, those are 28mm offset wheels and with 295mm tires?
      02-24-2016, 04:41 PM   #20
HoustonRider
big pimpin
Drives: 2014 M6 GC and 2015 4 GC
won't fit
2014 //M6 GC
2015 750Li
2015 435i GC
      02-24-2016, 06:29 PM   #21
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
In respect to and based upon?
