      07-01-2015, 04:54 PM   #1
nyy13lal24dal9
nyy13lal24dal9's Avatar
Drives: 15' M6 Gran Coupe
Wheel is rusting what can I do?
Two of my wheels are rusting. Same spot around the bmw logo only after I wash it. What can I do?
      07-01-2015, 05:22 PM   #2
troymi
Drives: '15 M235i Convertible
Pop your center cap out and rinse inside to see if that helps. Almost looks like it's rust from your hub that is running out of the center cap. The hub will rust. FYI, make sure to use a white lithium or similar lube on your wheel hub when you install your wheels. Otherwise, you will get them "locked" together. Especially in cold climates.
      07-03-2015, 04:51 AM   #3
RichardP
51
2013 BMW M6 Gran Coupe  [10.00]
1980 E26  [10.00]
2003 BMW M5  [10.00]
As above, it's not the wheel it's the hub.
These were mine after just a few months before I cleaned them up and coated them in copper grease.
      07-22-2015, 01:33 PM   #4
nyy13lal24dal9
Attachment 1237159
So all I have to do is pop the center cap off? Not the whole wheel right?
      07-22-2015, 01:39 PM   #5
RichardP
51
1980 E26  [10.00]
2003 BMW M5  [10.00]
No, take the wheels off.
      07-22-2015, 04:46 PM   #6
nyy13lal24dal9
Ok thank you. I am taking it down to BMW on Saturday to have them do it, Its getting worse and its happening to multiple wheels.
