      03-19-2024, 02:06 PM   #1
Sauceii World
Drives: g12 750xi , f13 M6
Going catless downpipes do you need new plugs gapped differently?
Any other car I ran catless on I simply tuned right after and was good to go . I ran into a video where someone stated you needed to get new plugs and gap them differently. Wanted to check here if that was true as I know a bunch of you are running catless and tuned . Current mods RK front mount intakes and charge pipes . Bootmod3 license and tune ready but not flashed until I go catless and do my exhaust . Thanks in advance
      03-20-2024, 11:36 AM   #2
Flo1989
Flo1989's Avatar
342
Drives: M6 Gran Coupe
If you run an actual stage 2 file, you should get one step colder plugs and gap them properly. If you intend on running a stage 1 file and just have the CEL coded off to run catless DP's, then you don't need new plugs. With that being said, I would suggest that you don't skip out on the "non fun"/support-mods when starting to add power to these cars. You'll thank yourself later.
      03-20-2024, 12:00 PM   #3
Sauceii World
Since it’s my daily driver I plan on at the very most running stage 2 93 octane. Won’t be going past that power wise . What non fun mods would you suggest ?
      03-20-2024, 11:20 PM   #4
Flo1989
Flo1989's Avatar
342
Then I’d say get the proper plugs and gap them. I was referring to the upgraded plugs when I said non fun mods. Basically, things that don’t bring visual improvements or increase power/tq to the car, but should be done to make sure the car performs optimally.
      03-20-2024, 11:37 PM   #5
Sauceii World
I’ve tried to use the search function here but haven’t found exactly what I’m looking for . Do you recall any threads with the exact plug info ?
      03-21-2024, 03:13 PM   #6
Flo1989
Flo1989's Avatar
342
Here ya go! https://www.ecstuning.com/b-ngk-part...f-8/97506s8kt/
I'm not sure what bootmod would suggest for GAP, each tuner is different. For reference, my gaps are .019. My guess is that they'll tell you to run .020-.022
      03-22-2024, 07:33 PM   #7
Sauceii World
Thanks so much !
Flo1989342.00
      03-22-2024, 08:14 PM   #8
Sauceii World
Sent you a dm with an additional question
