      01-05-2018, 01:05 PM   #1
14M6GCoupe
Drives: 2014 btw m6 grand coupe
21 tires question!!!
I have 265/30/21 i was wondering if i can put 275/30/21? Does any boy have try this or knw about this! Help pls i have to buy a set i dnt want to buy the wrong tires! Thankz! 2014 bmw m6 gc
      01-05-2018, 06:22 PM   #2
14M6GCoupe
Anybody???
      01-06-2018, 01:23 PM   #3
mastatikle
Drives: m3
They’ll both fit up front. It just depends on your rear tire size.
      01-06-2018, 04:30 PM   #4
14M6GCoupe
I was thinking 325 30 21
      01-06-2018, 10:33 PM   #5
98mkiv
Drives: 09 335d
so just do the math. You want your tire diameter to remain constant.
WWW/RR-DD
Use the formula (DD*25.4)+(2*(WWW*(RR/100)) = Outer diameter of tire
Apply that to your stock tire size.
Your new tire size should be adjusted so that the D/R/W comes out to the same number. That way your speedo stays accurate and your suspension geometry also works the way it was designed to. Keep in mind this does not account for width, meaning you might rub on the fenders or suspension parts over bumps or during turns.
Hope that that helps.
If you have a question - put up your factory tire sizes and your proposed sizes.
      01-07-2018, 02:25 AM   #6
mastatikle
Drives: m3
Front and rear tire have to me close to the same diameter or else the car won’t run right. Ask me how I know... I have 325/30/21 in the rear and 275/35/21 in the front and it rubs a good amount. But the car also drives normally. I plan to downsize to 255/35/21 to bring diameter down a bit so it doesn’t rub. 275/30/21 might be too small. I had 255/30/21 in front and it fit but since rear tire diameter was like 2” taller the car wouldn’t shift right.
      01-07-2018, 08:26 PM   #7
14M6GCoupe
Ohh okai i see what u saying
      01-07-2018, 08:28 PM   #8
14M6GCoupe
WWW/RR-DD
Lol big equation my friend ill figured it out some how thank u for the help!
      01-10-2018, 06:27 PM   #9
14M6GCoupe
Have anybody try out 325 30 21 on the rear and 267/275 3 21 on the front? Does that is a good match? Help pls
      01-10-2018, 06:37 PM   #10
mastatikle
Drives: m3
What for front?
      01-10-2018, 07:48 PM   #11
14M6GCoupe
What for front?
265 30 21 or 275 30 21
