09-01-2016, 06:38 AM | #23 | |
Rep 8,970
Thanks! I have -20mm lowered eibach springs on my M6GC and want to judge which spacer width to go for. |
09-05-2016, 12:19 AM | #25 |
Rep 417
Running 15mm spacers all around on OEM wheels.
09-05-2016, 01:14 AM | #26 |
Rep 21
Anyone know of other BMW model spacers will work? I have ones for the previous model 5 series but checking online, the current 6 series don't come up as a match.
Surely all 120pcd spacers are the same?? |
09-05-2016, 02:16 AM | #27 | |
Rep 8,970
E9x 3 series are 72.6mm, amongst others, my spacers are from my old 335i. You'll need extended bolts and the M5/6 uses M14x1.25 thread, most other BMW are M12x1.5 so won't fit. The new bolts and locking bolts cost me more than the spacers! Last edited by doughboy; 09-05-2016 at 02:24 AM.. |
09-05-2016, 03:06 AM | #29 | |
Rep 21
09-05-2016, 08:54 PM | #30 |
Rep 417
Here are some pictures. Hopefully they are what you need. I think it looks aggressive but not overdone.
09-05-2016, 08:57 PM | #31 | |
Rep 676
Drives: 2015 M6 Gran Coupe
I didn't know eibach makes springs for the M6 now |
09-06-2016, 02:08 AM | #32 |
Rep 8,970
Thanks guys, appreciate the photos, both great looking cars!
I think the 15mm is a little too aggressive for me, but the 10mm looks just right and I have a GC also with the same wheels. The eibach springs are on the UK/Europe website but not on the US one...strange. http://www.eibachshop.co.uk/eibach-p...m#.V85q3JgrJi8 But If I had my time again I would have bought the AC schnitzer springs, better ride. |
speedracerlo305.50 kris1858555.00 |
09-09-2016, 01:55 AM | #34 |
Rep 8,970
M14 x 1.25 thread
Black, 17mm hex head 60deg fixed taper / cone seat Standard length 27mm (from thread tip to small end of seat) http://www.realoem.com/bmw/enUS/show...diagId=36_1809 Part 3 for OE bolt |
09-14-2016, 05:41 PM | #39 |
Super Member
129
Rep 344
Looks damn good! Are you lowered?
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust |
09-14-2016, 08:05 PM | #40 |
Rep 417
Thanks!
Nope, still on stock suspension. The vorsteiner CF aero kit gives it a lowered appearance.
09-24-2016, 07:40 AM | #41 |
Rep 21
Just wanted to warn those thinking to do this. Make sure you get some quality spacers. I purchased a set of aluminum ones off eBay and narrowly avoided a disaster. Put them on myself and torqued. Did this in my carpark and left it overnight, next day I wanted to double check and all nuts were lose. I tighter then up and moved slightly and again they were loose. Did this a few times and decided not to take the car out. Just took the wheels off and the hub rings were snapped off!
I'm staying away from this spacer thing despite having done the same on my last 5 rides. I must be getting old and not a risk taker anymore.... |
10-04-2016, 03:58 AM | #42 |
Rep 69
Drives: M6 14 GC frozen grey & 21 M2C
10-04-2016, 04:29 AM | #43 |
Rep 8,970
You will need longer bolts for sure. Standard bolts won't even reach the hub through a 10mm spacer.
Extend bolts by same thickness as spacer if possible. Standard m6 is 28mm, so 40mm is good for 10- 12mm spacers. But 20 black bolts costs almost the same as the spacers.... most bolts are silver which looks terrible on a bmw. |
