      02-26-2017, 12:16 PM   #1
M_Coupe1999
Drives: E46 M3 LSB VF Eng. Stage II
Question WTB 8mm spacers for M6GC hubcentric?
Hey all,
As the title says, cant seem to find a set of 8mm hubcentric spacers with their bolts.
Will extended bolts be needed for 8mm?
      02-26-2017, 12:20 PM   #2
M_Coupe1999
7mm or 7.5mm will also do not less.
I currently have 10mm and its a bit more than needed.
      02-26-2017, 12:38 PM   #3
Vegas_M6_GC
Vegas_M6_GC's Avatar
Drives: M6 GC CP, Merc GLE43, 535I MSp
H&R may have them. You'll need to buy extended bolt separately. But high quality, these are the only things holding your wheels in place! There are debates on min spacers starting at 10mm. Just to be safe, I went with 10/12 with BMS, worked out very well. 12/15 was too aggressive as I am planning to replace rear wheel with 305/30 and it would definitely flare way out there leading to damage of the wheel well.
      02-28-2017, 01:25 PM   #4
M_Coupe1999
H&R doesnt have 7.5mm spacers when you select the M6GC. Don't know why.
There is 5mm and 10mm.
      03-01-2017, 10:43 AM   #5
melvyn
Drives: 2018 M3 CS
Hi
Are you running the 601 CP wheels, are you going to go 275/35 on fronts as well when you go 305/30
      03-01-2017, 12:09 PM   #6
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
You can have a set custom milled. Have done it a couple times. There's a company in Nevada I think. Awesome customer service.
      03-01-2017, 01:32 PM   #7
Vegas_M6_GC
Yes. I have 601s. 12 in the back may be pushing it. Worst case, 10mm All around. I will know in a few months.
