02-26-2017, 12:16 PM | #1 |
Rep 35
WTB 8mm spacers for M6GC hubcentric?
Hey all,
As the title says, cant seem to find a set of 8mm hubcentric spacers with their bolts. Will extended bolts be needed for 8mm? |
02-26-2017, 12:38 PM | #3 |
Rep 17
H&R may have them. You'll need to buy extended bolt separately. But high quality, these are the only things holding your wheels in place! There are debates on min spacers starting at 10mm. Just to be safe, I went with 10/12 with BMS, worked out very well. 12/15 was too aggressive as I am planning to replace rear wheel with 305/30 and it would definitely flare way out there leading to damage of the wheel well.
03-01-2017, 10:43 AM | #5 | |
Rep 436
Are you running the 601 CP wheels, are you going to go 275/35 on fronts as well when you go 305/30 |
03-01-2017, 12:09 PM | #6 |
Rep 1,719
You can have a set custom milled. Have done it a couple times. There's a company in Nevada I think. Awesome customer service.
