      05-19-2024, 05:51 PM   #1
OnlyGerman
OnlyGerman's Avatar
Drives: G12, F15, F13, F10, E60
Can these micro scratches be corrected or do I need a new headlight / lens?
Haven’t tried any of the restoration kits as I’m not sure if it’s even worth it.
      05-19-2024, 09:38 PM   #2
Opie55
Drives: '15 650i Convertible
That can be made to look literally like new in under an hour. Headlights have a relatively thick UV coating on them, and that is what gets all cracked like that. It needs to be wet sanded off and a new coating of some kind applied. There are a fair number of posts about the process including some by me. So I won’t type it all out again. But run some searches.
      05-20-2024, 08:27 AM   #3
OnlyGerman
OnlyGerman's Avatar
Thank you! I was getting conflicting info from some shops. I’ll definitely try fixing it.
      05-20-2024, 09:10 AM   #4
Opie55
Thoroughness is the key. You MUST erase all scratches from the prior grit with each finer grit. It's not rocket science, but there are a lot of threads with people saying "it looks a lot better, but you can see a bunch of scratches." It's 10 minutes between that and perfection.
      07-19-2024, 07:59 PM   #5
OnlyGerman
OnlyGerman's Avatar
Thanks for advise. I took it to my friends Bodyshop and he got it looking almost like new
      07-20-2024, 05:59 AM   #6
MADBMWX5MC
MADBMWX5MC's Avatar
Drives: 2023 BMW X5MC
How, was it, like clear coated or something?
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (show car)
      07-21-2024, 12:22 PM   #7
Qsilver7
Qsilver7's Avatar
      07-21-2024, 01:32 PM   #8
Ralph III
Drives: 2018 BMW 650i Gran Coupe
Hello OP,
Like Madbmx inquired. Did your friend sand and then clear coat it? Because if he just sanded and buffed it, it won't last. You need a new layer of UV protection applied because the coating that was on your lens is cracking and thus failing. I'm a former professional Detailer (14 yrs) and have a video, as found HERE, for a quick restoration. This was on a lens where the clear coat had just faded/yellowed. So, I can expect several more years out of it. Yours is beyond that and it needs more clear applied.
Good luck,
Ralph
