      02-24-2024, 09:34 AM   #1
Curlyred
Drives: BMW F12 M6
F12 M6 Misfire issue
Hi - I would be extremely grateful for some advice on the issue I have with my 2013 BMW M6.
It has the S63 Twin Turbo V8 - It suddenly went into reduced power/drivetrain fault and upon interrogation by my close friend who is a Williams BMW Technician , cylinder 2 bank 2 is being shut down by the DME.
Trying to avoid crazy main dealer labour charges here. We have checked the obvious, changed the plug and coil and even replaced the injector - all to no avail.
My friend is absolutely stumped as to what to do or what the issue is. It does not appear to have any untoward obvious mechanical noises , ticking etc so can’t believe it’s a valve or cylinder problem. Car has been well maintained and only covered 44k. Had it idling fine on all cylinders for ten minutes after injector replaced but as soon as throttle applied it went in to drivetrain fault again.
I would be very appreciative if anyone could perhaps give us some suggestions as to where the fault may lie and what to do next to try to pinpoint the exact issue. Thank you
      02-25-2024, 04:11 AM   #2
Kick 6
Kick 6's Avatar
286
Drives: BMW M6
Are the spark plugs gapped correctly?
2018 M6 Gran Coupe> DME Stage 2 ECU Remap>Xpress Power Catless Downpipes>Resonator Delete> KW Height Adjustable Springs>Rear Carbon Fiber Diffuser>Carbon Fiber Rear Spoiler>Carbon Fiber Mirrors>IND Painted Front Grille> IND Painted Front Reflector>JR-34 Gunmetal Wheels, 20mm Spacer on rear, 10mm Spacer on front>RK Autowerks Carbon Air Intake>Racing Dynamics Carbon Engine Cover>Carbon Steering Wheel
      02-25-2024, 10:22 PM   #3
Staszek
Schumacher
Staszek's Avatar
786
Drives: E30 325is,E93 M3,X7M50,F06 M6
I know it may be silly but how old is your battery? These things get crazy finicky when the battery is low or old. My E93 M3 started throwing all kinds of codes and misfires one day after I let it sit too long (the battery was 10 years old). Changed it out cleared the codes and its been fine ever since.
Long shot but worth checking.
      02-26-2024, 10:38 AM   #4
JDMSteven
JDMSteven's Avatar
Drives: '13 F13 M6, '94 JDM Supra
2013 BMW M6  [10.00]
Has the injector been coded correctly? Correct injector? Some take EU5 some take EU6. Take it to a BMW indy shop if your friend who is a BMW tech can't figure it out. I'm grateful to have a fantastic tech at my local indy shop who worked at the dealer for 15+ years. Cheaper labor rate than dealer, more experience, plus they are happy to install all my aftermarket parts
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents
      02-26-2024, 01:01 PM   #5
danielgmanm6
danielgmanm6's Avatar
Drives: 2013 BMW ///M6 F13
2013 Bmw M6  [0.00]
  [0.00]
  [0.00]
If you have a 2013 your car takes EU5 injectors not the updated EU6. I would check that first.
      03-01-2024, 08:58 PM   #6
AbedChaar
Drives: 2016 BMW M6 gran coupe
I have the same problem but cylinder 7.
replaced plugs/coils and injector all OEM. drove good for 1 day than came back. have no clue what to do next. let me know if you have found a solution please
