09-07-2023, 03:56 PM | #2 |
Rep 631
left one is subframe to body ground strap. There are three connectors at the right rear wheel, the wheel speed sensor, which would give an ABS error it it is loose. The brake pad wear sensor, which this in definitely not and the electric hard brake motor, which this one could be. Sorry but it is to darn hot to go jack up the car to check it out (103F and even hotter in the garage)
F06 M6 Grand Coupe CP
09-07-2023, 04:05 PM | #3 |
Rep 7,484
Does the one on the right have the 11 or 7 digit BMW part nbr on it or on the label?
Hopefully you know what the 11 digit BMW part nbr looks like (xx xx x xxx xxx)...or if it is small...the BMW part nbr may only list the last 7 digits (x xxx xxx).
09-07-2023, 11:07 PM | #4 | |
Rep 37
