      08-26-2023, 07:58 PM   #1
abhiT
Drives: Audi A4
640i xDrive 2D coupe 81k
Hello folks,
An Audi owner here. BUT made up my mind to change teams. Fed up with the unreliability of the VAG manufacturer. Looking at a 2016 640i xDrive 2D Coupe with 81k miles.
Read some info on the N55 inline 6. Some issues I already know to look for
VANOS failure
Valve cover leak
Water pump failure
What else do you advise I should look out for ? And what are the 3rd party repair costs for the above ?
Not into engine mods or tunes. Just want a reliable, fast machine
      09-07-2023, 01:57 PM   #2
zz6938
Drives: X5
most reliable engine you can buy for this car. suggestion - Stay away from N63s.
water pump has extended warranty by BMW NA.
yes valve cover will leak and it will be about 1200 bucks unless you want to diy it.
      09-07-2023, 01:59 PM   #3
zz6938
Drives: X5
unless you have to, be mindful about x drive as well. Transfer case with these may present a problem later on.
      09-07-2023, 08:45 PM   #4
Chaos236
Chaos236's Avatar
209
Drives: Porsche Cayenne , 640 GC
Just do oil filter housing and that cheap plastic hose that runs along the front edge of engine Also charge pipe whether needed or not.
