      08-16-2018, 08:43 AM   #1
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
2024-1 North America NEXT map
2024-1 North America NEXT map is now available.
Note: I don't sell FSC codes.
MAP file part 1 here >>>: https://drive.google.com/drive/folde...-X?usp=sharing
MAP file part 2 here >>>: https://drive.google.com/drive/folde...lP?usp=sharing
>>> Fix download quota exceeded <<<
1: Select link with the file which you are trying to download
- when the web page loads, login with your Google account
2: Right click on file & select make a copy
3: Navigate to your google drive, My Drive folder & locate the file you want to download
4: Right click on file & click on download
5: When you finish downloading, delete the file from your My Drive folder then go to the trash & delete it forever.
Repeat steps above for the 2nd map link.
>>> Saving map files|folders to USB Flash drive <<<
- 64GB or bigger capacity required
- FAT32 file system
1. Free software to format large capacity USB Flash drives to FAT32 >>>: http://ridgecrop.co.uk/download/fat32format.zip
2. Free software to format large capacity USB Flash drives to FAT32 >>>: https://rufus.ie/en_US/
- Boot selection = Non bootable
- Partition Scheme = MBR
- File system = Large FAT32
1. Map files|folders must be saved on the root of the USB Flash drive
2. When viewing contents of the USB Flash drive, you should ONLY see the files|folders below.
3. If they are inside another folder or if there are hidden files (added by using a MAC\OSX) then it will not work.
From wt888
Many drives are seen by the PC as "Local Drive" in "My computer", as if they were backup hard drives, not portable memory sticks.
After inserting the USB drive into your car and getting a message to update it, an error message then says to insert the USB drive, and you can't get past it.
The solution is actually to use a USB FLASH drive that is recognized as "USB Drive" in "My computer".
If it shows up as Local Drive, your car won't see it as a USB drive either.
The solution is to get another USB Flash drive.
USB Flash drive I use: https://www.amazon.com/Patriot-Super...tronics&sr=1-1
TIP: Buckle driver side seatbelt to prevent iDrive from going to sleep during the upgrade
>>> Create DE.FSC file which is required by the FSC Generator <<<
Requirement: E-Sys & ENET cable
Prerequisite: disable all firewalls, Antivirus. Set Ethernet to DHCP (not static). EDIABAS 7.3.0 installed
1. Connect ENET cable to OBD port
2. Connect ENET to laptop Ethernet port
3. Wait until ALL lights in instrument cluster\dash turns off
4. Turn on Ignition, press START button (DO NOT step on the brakes, engine does not have to be on)
5. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig
6. Ensure you have 169.254.xxx.xxx IP address for Ethernet
7. Wait 2 minutes
8. Launch E-Sys
9. Select Connect
10. Select appropriate Target (based on I-Level)
Note: Don’t use _DIRECT
11. Select Connection via VIN
12. Select Connect
13. Click Expert Mode
14. Select FSC Extended
15. Diagnostic Address (hex) = 0x63
16. Click Identify
17. Application Number (hex/dec) – 0xDE
18. Upgrade Index (hex/dec) – 0x1
19. Scroll down & select StoreFSC
20. Select Add to the batch button (>>)
21. Select Read
22. Select Save
23. Use the following naming format when saving FSC file. XXXXXXX_000DE001.fsc
Note: XXXXXXX is the last 7 of your VIN
Uploaded all the files I use here >>>: https://drive.google.com/drive/folde...Nl?usp=sharing
Free software to extract the compressed files & folders >>>: https://www.7-zip.org/
BMW_CIC_FSC_Generator.zip download location >>>: https://mega.nz/file/PFsHHYLY#pYF4sv...wzhvVvINin5Rnk
>>> Generating FSC code for map updates - BMW_CIC_FSC_Generator.exe <<<
All credit goes to the software developer(s)
1. Extract BMW_CIC_FSC_Generator.exe from the ZIP file
2. Open BMW_CIC_FSC_Generator.exe
3. Select OK to download Lookup.xml file (computer needs internet access)
4. Select OK then close and open the program again
5. Select NBT then use Browse button to select FSC file created with E-Sys & ENET
Map type = Next
Region = NORTH AMERICA
Maps = ROAD MAP NORTH AMERICA NEXT 2021-1
Suggestion: check mark on Lifetime
Select Generate button
>>> Determine Region & Map sequence code <<<
Note: requires HxD application: https://mh-nexus.de/en/hxd/
Region & Map sequence code - located in the 1st folder of the map files
File path = 1\INFO_MAP_NANT_#####\Info_Map.imp
North America NEXT:
      08-16-2018, 09:36 AM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
Thanks for the info. Looks great. Can you please pm the link.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      08-16-2018, 04:20 PM   #3
mjposner
mjposner's Avatar
899
Drives: 2020 Z4 40i
link to me too please
      08-16-2018, 06:49 PM   #4
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
done & done
      08-17-2018, 03:07 PM   #5
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Can you PM me the link too?
Thanks!
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      08-17-2018, 03:45 PM   #6
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Thanks!
Done
ooshnoo877.50
      08-17-2018, 06:33 PM   #7
AECDY
Drives: BMW F15
Can you PM the link please.
      08-17-2018, 07:38 PM   #8
AECDY
Drives: BMW F15
Can you pm the link please
      08-17-2018, 09:57 PM   #9
schnell1982
Drives: FAST
I am interested also please.
Thank you !
      08-17-2018, 10:33 PM   #10
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Thank you !
Done & done
AECDY299.00
      08-20-2018, 03:40 PM   #11
vaio23
Drives: 650I
Please send me link
      08-20-2018, 03:53 PM   #12
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Originally Posted by vaio23 View Post
Please send me link
Done
      08-20-2018, 08:06 PM   #13
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
I would not mind to get a link too Thanks!
Freude am Fahren.
      08-21-2018, 08:15 AM   #14
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Done
      08-21-2018, 08:21 AM   #15
Allen Wang
Drives: 2014 M6 GC San Marino Blue
can you please PM the link?
      08-21-2018, 10:33 AM   #16
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Done
To be clear, the only map I have is for North America. Your location says Taiwan
      08-21-2018, 12:47 PM   #17
peloterogq
Drives: bmw x5 50i
Can You Share The Link Please
      08-21-2018, 01:02 PM   #18
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Done
      08-22-2018, 10:19 PM   #19
Bimmer Noob
Drives: 2015 550i
Can you please send the link? Thanks.
      08-22-2018, 10:46 PM   #20
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Done
      08-23-2018, 08:40 PM   #21
Siciliano611
Drives: SMB M6GC
Can you share the link?
      08-23-2018, 08:46 PM   #22
Siciliano611
Drives: SMB M6GC
Once I have the map file and the code from this walkthrough then how do you actually update the map in the car? Burn to DVD? USB?
