10-05-2016, 06:27 PM | #1 |
Rep 29
Can you upgrade existing car to Competition Pac?
?? Also what if they didnt make the CompPac for your year? Like I have a 2013 Convertible, could they turn mine into one?
10-06-2016, 01:20 AM | #2 |
Rep 436
No you can't .
You may be able to add the existing wheels, sports exhaust and springs and dampers for considerable money. If you have an existing CP built from August 14-15 you can add the HP upgrade to 600 HP (592bhp) which also tweaks the dampers and tc. |
10-06-2016, 03:13 AM | #3 | |
Rep 69
Drives: M6 14 GC frozen grey & 21 M2C
is there a way to check if it applies to my car before I do ? Thanks |
10-06-2016, 08:39 AM | #4 | |
Rep 436
Cars built after July(UK)14 with CP 575hp can have power upgrade, these cars have same springs and dampers and manifold as 2016 CP 600 HP models. 2014 model CP 560 HP can't have the upgrade. Mine was June 2015(UK) build 575hp CP, had upgrade put in .Price was £1k July -August 2015 CP (UK and USA)and onwards are 600hp: Hope this helps |
Murdock101222.50 |
10-10-2016, 07:26 AM | #5 | |
Rep 69
Tank you 600x |
10-22-2016, 10:00 AM | #6 |
M Master
74
Rep 551
You can do a power upgrade for 15 hp from the dealer, but you will get much more from a tuner..
As for the other Comp stuff.. Its basically a No.. You can upgrade your springs, sway bars, and bushing to the competition ones, but you will still lack the Competition Active Differential, and suspension/sport driving settings that are tweaked with the comp. pkg., and to find coding for this is impossible.. So just up your power and enjoy your car the way it is.
M History: E46 M3, E92 M3, E63 M6, F13 M6 Comp Pkg, E71 X6M
10-23-2016, 10:12 PM | #8 | |
Rep 51
Can you point me to anywhere that states BMW made 560HP competition package. Every article I read when they launched the comp pack stated 575hp, I have a comp pack m6 build before july 2014. Or did they only launch a 560hp version in UK? |
10-24-2016, 02:01 AM | #9 |
Rep 436
Having checked you are right buddy, my mistake
10-24-2016, 02:05 AM | #10 |
Rep 436
10-24-2016, 03:59 AM | #11 |
Rep 137
I understand what you are saying. It is in fact 25 hp upgrade, there is no upgrade possible from the 560 hp standard car. To get the 15hp upgrade you must buy a Competition Package when the car is new.
10-28-2016, 08:35 AM | #12 |
M Master
74
Rep 551
Depends where you live, some places will allow the HP update file to be added, other places/countries no.. But its pointless, just get a conservative tune if your worried and drive with 630hp BMW knows people tune the engines, they allow a certain amount of tolerance. With our cars, the transmission clutches will slip first before we reach engine conditions that are unsafe.. so with just a flash tune, you will make safe power and be well above the small amount the competition pkg ads.. I run ESS Flash on my M6 and its perfectly dialed in, safe and I dont have to mess with JB4, or map switching or testing.. thats if you prefer the easy safe route.. and switching back to stock is takes just a couple min with their cable.
01-31-2017, 12:33 AM | #13 |
Rep 17
Hi. New to the forum and just doing a search for M6 owners with ESS flash tune. Picked up a '14 M6 GC CP and thinking about bumping it up with ESS flash. Hate the feeling that the new 550ix can kick my butt from 0-60mph. Did you add DP or no? I'm on the fence in getting the Fabworks GESI catted DP or just go stock. May need to consider moving back to Cali and concerned about not passing smog check. I wonder if I have to reflash if I add DPs later?
01-31-2017, 02:01 AM | #14 | |
Rep 429
02-13-2017, 04:34 PM | #15 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Contact Halim@HCP
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-18-2017, 12:39 PM | #16 | |
Rep 1,857
Then again unless you track the car, otherwise the differential tuning won't matter much. |
02-20-2017, 10:08 AM | #17 | |
Rep 436
Either way, for 25hp , it would be minimal |
02-20-2017, 08:42 PM | #18 | ||
Rep 1,857
02-21-2017, 01:42 AM | #19 | |
Rep 436
CP 575 built July 14 to July 15 can have the upgrade as all components are exactly the same as the 600 CP built July 15, that's why BM allow the upgrade |
02-21-2017, 06:17 AM | #20 | |
Rep 1,857
Sorry for the confusion, guess you thought I was comparing the diff. between 575HP CP to 600HP CP. Last edited by Phatcat; 02-21-2017 at 06:50 AM.. |
02-21-2017, 07:41 AM | #21 | |
Rep 436
