      09-22-2013, 08:25 PM   #155
ColdList
ColdList's Avatar
154
Drives: McLaren 675LT / C7 Z07
The S101s look very nice and aggressive. Great job!
2016 McLaren 675LT - Chicane Grey
2016 Corvette Z07 - Artic White
2016 BMW F86 X6M - Black Sapphire Metallic
      09-23-2013, 07:52 AM   #156
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Thanks Cold, they are actually P101's....the S101's are triple piece.
My Thread:
      09-24-2013, 08:23 PM   #157
delano
Drives: 2013 M6 F12 & 2013 Rover S/C
I've heard of a number of guys going with 1 piece instead of 3 piece these days, I always thought 3 piece was a better wheel although I didn't really know why. Is there a benefit to the 1 piece?
      09-24-2013, 08:57 PM   #158
Hunter5179
Hunter5179's Avatar
Single Piece is always the best way to go as far as strength, performance and weight.. but a good triple piece can be just as strong. Things to consider with triple piece wheels are the separate pieces that have to be put together to form the wheel and the bolts used to secure those pieces as well as the sealant used to keep the pieces nice and air tight. Being that the triple piece wheels have all these factors to consider there is more room for errors or things that can go wrong which would compromise the wheels integrity. Triple piece wheels are always heavier than their single piece counter parts with the exception of a few. On the plus side triple piece wheels offer a wider array of custom options and unique designs which single piece wheels can't pull off. Nowadays triple piece wheels are a lot better than they used to be so you don't have to worry about a whole lot as long as you buy from a reputable company that has good quality control over their products. I like triple piece wheels mostly because of the lips you can have which you can't get with single piece.. Single piece have a tendency of looking conservative or OEM like so if you are spending a lot of money to not look custom then maybe you are better off staying stock or buying a triple piece wheel that will give you more of a custom look... not to say that single piece wheels can't give you a custom look.. its just a lot of them look conservative even if they are designed not to be. Hope this helps.
My Thread:
      09-24-2013, 09:41 PM   #159
bjayfan
Drives: 2014 F13 M6
What Hunter said, plus 3 piece are less expensive to produce. Creates a bit of a conflict these days since 3 piece are getting closer to strength and weight. P101's with a custom finish, which I think satan black is, somewhere around 10K, but in terms of performance not a lot that will touch them.
The wheels are beautiful, and not just in looks.
      09-25-2013, 12:00 PM   #160
noushy
///M Fan
noushy's Avatar
1657
Drives: M8 Comp, X5M Comp, iX M60
BJayfan the 3 piece wheels are more expensive to produce. The one piece wheels are machined solid from the get go. The three piece have labor to assemble and additional hardware. Same reason why list price of HRE 1 piece is usually $300-$600 less than the 3 piece. However monoblocks can weigh less and tend to be stronger because of the minimal lip. I own the S101s and I know the P101s are similar in weight, slightly different look and less concave, and also quite a bit cheaper as well. My last set was HRE monoblocks but I wanted to try something different and went with a three piece this time.
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      09-25-2013, 12:50 PM   #161
Hunter5179
Hunter5179's Avatar
Noushy
Noushy meister, you have a nice set of wheels but your Intel is off. The S101's aren't more concave then the P101's and they weigh more than the P101's approximately 4-5lbs more and there are various levels of concavity you can order the P series in. The P series is HRE's newest high performance line and they cost the same as the triple piece S series.. Relax or I'm going to drive to your house.
My Thread:
      09-25-2013, 01:03 PM   #162
noushy
///M Fan
noushy's Avatar
1657
Hunter they offered me $1700 a piece for the p101 and $2100 for the s101 per HRE and my dealer. Finishes and titanium hardware extra. Also told per rep that the extreme concavity only available via 3 piece. But this can be a discussion for another time. As with anyone spending $8k plus for wheels we can afford any of the ones we like. And their top of the line is the CF2 version of the S101. Look it up my friend now I have to go back to seeing patients
http://m.autoblog.com/2012/11/01/hre...els-sema-2012/
      09-25-2013, 01:08 PM   #163
Hunter5179
Hunter5179's Avatar
LOL. I have no words. I will let third party Intel chime in.. I'm on my way to your house... see you soon.
My Thread:
      09-25-2013, 01:09 PM   #164
noushy
///M Fan
noushy's Avatar
1657
Bring it. I will park the Alpina out front to guide you! Dont get lost navigating since numbers probably not your thing
      09-25-2013, 01:44 PM   #165
Hunter5179
Hunter5179's Avatar
Your going to make me launch my UAV and bomb your Alpina sport sedan for grandpa up before I get there.
My Thread:
      09-25-2013, 06:51 PM   #166
bjayfan
Drives: 2014 F13 M6
Thankfully I'm more than several hundred miles from both of you.
HRE quoted me $2,300 per wheel (two days ago) for the P101's, the custom finishes were $250 per wheel. I know you can do better through a dealer, both of you are closer to me than their nearest dealer.
I don't know if you got your wheel prices reversed, someone is playing games with what they have (or don't), or if they're trying to build in shipping. I'll call again tomorrow and get S pricing.
I have zero experience with 3 piece wheels, but I've probably been putting wheels on cars a bit longer. Perhaps 3 piece have come further than I know, but then weight and strength have always been a priority for me. So long as they look OK, I'm happiest to reduce the unsprung.
      09-25-2013, 11:03 PM   #167
noushy
///M Fan
noushy's Avatar
1657
There is quite a bit of markup on my S101s. My 20s listed for $2400 plus $100 per wheel to have the inner barrels black satin. The exterior finishes are included unless you do custom colors. Titanium fasteners are $1000 per wheel and drop one pound each wheel. My dealer paid $1840 or so and charged me $2100 as a returning customer (7th set of HRE wheels). I paid for the sensors and tax as well.
Peace
Noushy
BTW Hunter that large blue blur that passed you was the Alpina giving you an arse whoopin...
      09-25-2013, 11:24 PM   #168
delano
Thanks for the detailed description Hunter, I actually just put 3 piece HREs on the wifeys Rover so I guess I should have know the difference lol.
24 inch inch 943RLs at $3k per wheel, they are perfect. My 6 week old son has no idea how styling he and his moms whip is
      09-26-2013, 12:10 AM   #169
Hunter5179
Hunter5179's Avatar
No Problem Delano, indeed they are styling hard . Post a pic of that bad boy.
My Thread:
      09-27-2013, 09:20 AM   #170
noushy
///M Fan
noushy's Avatar
1657
Wheels weights officially from HRE for the F12/F13 20 inch fitments are 26/27lb front and rear for the three piece and 22/24lb for the one piece. Obviously 21 inchers weigh more and using titanium fasteners drop one pound on the three piece.
Enjoy,
Noushy
      09-27-2013, 10:32 AM   #171
Jason yaco
Drives: BMW M6 convertible
Great info guys thanks going nuts waiting on my s101s and other stuff. I almost got p101s same price my choice but I was looking for more of a look then track rim on this car I hope I made the correct choice? I went with the 21s
      09-27-2013, 02:56 PM   #172
Hunter5179
Hunter5179's Avatar
Enjoy,
Noushy
Damn noushy, you've got some heavy ass wheels. 21" P101s are rated at 21-23lbs depending on width size.
You did great! Your car will look fantastic... don't worry!
My Thread:
      09-27-2013, 02:58 PM   #173
delano
I think 21s are perfect for these cars, cant wait for some pics of them on!
      09-27-2013, 03:20 PM   #174
Hunter5179
Hunter5179's Avatar
Here are some quick teaser shots. Just slapped them on. I will go wash the car and snap some more pics and post.
My Thread:
      09-27-2013, 05:10 PM   #175
noushy
///M Fan
noushy's Avatar
1657
Hunter I forwarded you the email from HRE and for the 20s same offset and size as my S101s the P101s weigh 22/24 f/r but you can fantasize all you want I still love ya.
Noushy
BTW they look great!
      09-27-2013, 05:19 PM   #176
Hunter5179
Hunter5179's Avatar
Noushy
LOL.
My Thread:
