      07-12-2013, 10:04 PM   #89
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Ok guys. Update on the DP's.... Absolutely Awesome. the Akra exhaust now sounds phenomenal. Like an F1 car sound. The power gains are definitely noticeable.. No drone or anything unpleasant in the slightest. I'm sure DP's do wonders no matter what exhaust you are using, I'm just referring to mine because that's what I'm hearing. No point in having a sound system anymore since the symphony coming from my car is much more appealing to listen to. I highly recommend this mod so pick your poison and go for it.
My Thread:
      07-13-2013, 12:30 AM   #90
delano
Drives: 2013 M6 F12 & 2013 Rover S/C
Was the Akra exhaust sound noticeably different from the stock before the DPs? I finally got to listen to some Akras in person on an M5 today (the 2 biggest tuners in my town hadnt done an exhaust on the new Ms before this one today which seems odd). I was a little disappointed that they weren't too much different than my stocks. The high RPMs were better for sure but I was expecting something more dramatic overall. Could it be cause the M6 is louder to begin with compared to the M5, wouldn't make much sense cause they're the same motor? Not sure if my expectations were too high after your guys talking about how much you liked them, or if that's what's to be expected from a nice exhaust?
      07-13-2013, 06:05 AM   #91
RDH
Drives: F13 M6 Coupe
^^Run a sound clip please ...would like to hear....thanks in advance
      07-13-2013, 10:18 AM   #92
Hunter5179
Hunter5179's Avatar
I can't really comment on the stock exhaust sound to much as I changed my exhaust right after break in so I never really got a chance to open the stock exhaust up. I have however heard the stock exhaust in passing on a couple M6's and the sound is Def different. Loudness wise I know exactly what you mean when you use the word dramatic describing the Akra because it does sound deceivingly quiet especially from inside the cabin. Adding DP's adds serious drama to the sound of the Akra and opens up the the exotic exhaust note like never heard before. It's still tame when casually cruising so you don't have to worry about being to loud or anything like that but step on the gas in any kind of way and be prepared for a ton of DRAMA..... I honestly haven't turned my sound system on since the install and my sound system is a thing of beauty to hear.... The exhaust note now is absolutely incredible. A perfect mix of beauty and the beast. The car still retains the class but now has a ferocious quality to it. I can't describe it other than its like an F1 car mixed in with a hybrid beast of some kind. It's like the Akra gaining 1000lbs of muscle and tearing out of its clothing. Not sure what DP's do to a stock setup, I'm sure they will do wonders but from my experience with my current setup I can only describe it as all around perfect. People break their necks looking not because it's obnoxious loud or disturbing the peace but because it's otherworldly to them. Throw in the intakes and you have a plethora of sound coming from the car which comes together to form a symphony of beautiful, exotic, ferocious and intoxicating Bliss.
I'll post some vids /pics soon
My Thread:
      07-13-2013, 12:08 PM   #93
delano
Wow, your description of the Akra with the DPs sounds perfect. Both tuners made me think the DPs would be a bit obnoxious but it sounds like the perfect blend of mellow enough for cruising but super aggressive when you get on it. I'm sold.
You mentioned a tune, but I thought they can't crack the codes yet to do a tune? Do I need a tune to make the exhaust and DPs work right without issues? Thanks again for the input, your whip is inspiring!
      07-13-2013, 12:26 PM   #94
Hunter5179
Hunter5179's Avatar
It truly is a perfect combo. Don't forget I have race catted downpipes not catless. Eurocharged has a tune for the M5/M6. The top speed limiter is hard to crack but how often will u be going over 165 so it's not a deal breaker. You dont need a tune to run the downpipes or anything however a proper tune that takes all these mods into consideration will maximize performance. You won't have any issues running these mods tuneless and my cold start isn't any louder either. If anything the added sound change the DPs added might have even chilled the high pitch sound the exhaust would make on cold start a little.
My Thread:
      07-13-2013, 01:47 PM   #95
///M3Owner
///M3Owner's Avatar
99
Drives: 2011 E92 M3
that is very sexy, im jealous
2011 E92 M3 Metallic White Competition Package
      07-13-2013, 10:36 PM   #96
delano
Thanks again for all the info, one last question. Sounds like Dinan is pretty close to finally coming out with their tune for them and I was wondering if I should wait for that or do you think it'll be similar to what I can get from Eurocharged so no need to wait? Thanks!
      07-14-2013, 01:00 PM   #97
Hunter5179
Hunter5179's Avatar
No problem, anytime... as far as tune is concerned it's pretty much up to you. Dinan tunes are obviously good because they are dealer recognized and come with a warranty. Dinan tunes tend to be on the weak side and that is probably my only issue with Dinan. Another benefit is that the Dinan tune will have the top speed limiter removed. Eurocharged tune will definitely impress you and you won't be looking for more power that's for sure. It's a solid tune with OE origins. They adjust the fuel air mixture a bit and obviously like all adjust the boost levels. You Def can't go wrong with Eurocharged and if all other factors equal I would tell you 100% go Eurocharged over Dinan from experience with both. The only thing that's a huge plus but might leave you looking/wanting more is again that Dinan is backed by BMW and they should have the top speed limiter removed. I hope this helps.
My Thread:
      07-15-2013, 03:29 PM   #98
delano
Great input, thanks brotha!
      07-19-2013, 10:18 PM   #99
Hunter5179
Hunter5179's Avatar
Pics of them on the car next week
My Thread:
      07-27-2013, 05:53 PM   #100
Hunter5179
Hunter5179's Avatar
Car is dirty but here are a couple pics.
My Thread:
      07-27-2013, 08:27 PM   #101
noushy
///M Fan
noushy's Avatar
1657
Drives: M8 Comp, X5M Comp, iX M60
My new name for you... 'Dark Sexy' like the evil twin of my car!
Noushy
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      07-27-2013, 10:04 PM   #102
Hunter5179
Hunter5179's Avatar
Noushy
My Thread:
      07-28-2013, 01:10 AM   #103
delano
Looking good, I like them a lot better than the dark blacks you had before. Still looks sinister but not the over the top murdered out vibe.
Curios why you waited a month to put them on, you posted pics of them last month and I'd have thought you'd get them on quick. I've been waiting 5 weeks for mine and I think about them daily, they're going on the day they arrive lol.
      07-28-2013, 02:19 AM   #104
Hunter5179
Hunter5179's Avatar
Thanks, I had them sent back out to have the centers refinished. They were initially matte but were made gloss.. the rest of the time I was out of town. What wheels did you decide to order?
My Thread:
      07-28-2013, 02:38 AM   #105
delano
Haha I like your style, the devils in the details. I'm getting 21 inch D2 Forged, titanium brushed fronts, chrome lips, black inner barrels.
I ordered some 24 inch HREs for the wifeys Rover and those have already been over 8 weeks. I'm dying for some wheels for my whips lol!
      07-28-2013, 02:42 AM   #106
Hunter5179
Hunter5179's Avatar
Nice, I hear ya on the waiting man. Wheels can be a pain the ass. Looking forward to seeing yours when ready. Hopefully soon! Lol
My Thread:
      07-28-2013, 03:12 PM   #107
Blindside_137
Blindside_137's Avatar
Drives: 2011.75 SSII E90 M3 ZCP
Wow. Car is incredible! Love the transformations.
      07-28-2013, 05:33 PM   #108
ColdList
ColdList's Avatar
154
Drives: McLaren 675LT / C7 Z07
Looks great. Subtle aggressiveness. Absolutely love it. Nice job!
      07-29-2013, 12:27 PM   #109
Vic55
Vic55's Avatar
19365
Drives: 2023 BMW M8 Competition Coupe
Good stuff Constantine...
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      07-29-2013, 10:13 PM   #110
noushy
///M Fan
noushy's Avatar
1657
Delano it seems we all were waiting. HRE told me 6-8 weeks ended up being almost 12. Still I believe in quality and at the prices these guys are charging it should be perfect. I worry that 21 inchers will add too much unsprung wait and affect the ride. Even the tires weigh more.
