      10-12-2015, 11:55 AM   #1
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Lightbulb Dyno numbers - Stage 2 Dinan + M Performance Exhaust
Had my car dyno'd to see what she put to the wheel...
What do you think??
WHP: 567 hp
Torque: 532 lb-ft
      10-12-2015, 07:05 PM   #2
N.S.A
Drives: 991 GT3 Blue Sapphire Metallic
What do you think??
WHP: 567 hp
Torque: 534 lb-ft
Pretty good numbers that's like almost 700hp at the crank
-2015 991 GT3 Porsche Blue Sapphire Metallic
-2016 BMW ///M4 Yas Marina Blue Metallic with M Performance Exhaust
-2015 BMW ///M6 Gran Coupe Frozen Black with Full Akrapovic Evolution Exhaust SOLD
-2014 BMW ///M5 Black Sapphire Metallic with Full Akrapovic Evolution Exhaust SOLD
-2013 BMW ///M3 Limerock Park Edition SOLD
      10-16-2015, 09:04 AM   #3
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
How much did it put down before?
You could simply gain more power with a flash tune, but no doubt, nice reliable power.
      10-16-2015, 09:23 AM   #4
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
I haven't dyno'd my car yet (in the plans for this Fall), but the Turner dyno sheet for their tuning module shows 585 HP/525 ft-lbs. So little more HP, but little less TQ. Every dyno is different, and I figure the Turner module might be a little more aggressive than the Dinan (since they don't have the warranty to worry about). So yeah, I'd say that seems right. Assuming 15% drivetrain loss, that has you at ~670 HP at the crank, which isn't too shabby
      10-16-2015, 09:55 AM   #5
C5driver
C5driver's Avatar
3471
Drives: 55...just kidding.
I've been eyeing this module for a while, so post results and your impressions when you're done!
      10-16-2015, 10:44 AM   #6
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Considering 12-15% drivetrain loss, Crank power would be 644-667 HP and Crank TQ would be 606-628 lb-ft ...
      10-16-2015, 11:35 AM   #7
devondragon
C5driver - will do! The butt-dyno is impressed, and various methods of comparison (my favorite on-ramp, comparing speeds at various points on the track using the M Lap Timer app from before and after the module, etc... ) show noticeable increase in acceleration (once going fast enough to put the power down) (5-10 MPH faster). But my plan is to get up to Granite Dyno this Fall and get some real numbers. Will post here when I do!
      10-16-2015, 10:51 PM   #8
N.S.A
Oh I see, thanks for doing the math. I just took a guess on the top of my head. Good numbers for the crank
      10-18-2015, 08:37 PM   #9
PRican//M614
Drives: 2014 BMW M6, 2015 BMW X5...
Yes it izzzzz.....
      10-21-2015, 02:31 AM   #10
BBLF13
BMW Enthusiast
BBLF13's Avatar
Drives: 14' 650i Coupe
How do you convert whp to crank? any formula? Thanks
-Noob regarding dynos.
14' 650i Coupe.
Alpine White
M-Sport Package
Dinan Stage 1
H&R Lowering Kit
      10-21-2015, 07:18 AM   #11
devondragon
Basically you just need to calculate drivetrain losses, which vary between types of drivetrains. I've always heard that BMW RWD has roughly a 15% loss.
CHP - (CHP * 0.15)= WHP
CHP * 0.85 = WHP
CHP = WHP/0.85
      10-21-2015, 04:31 PM   #12
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
CHP * 0.85 = WHP
CHP = WHP/0.85
Well lets be realistic since today's car have a lot better drivetrian loss.
For RWD you can consider 12% and for AWD you can consider 15%
      10-21-2015, 06:49 PM   #13
devondragon
M6-Coupe - not that I'm doubting you, but do you have any sources for that?
      10-21-2015, 08:41 PM   #14
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
No I don't have any source and I doubt you can find any source, but I can tell you most of the drivetrain losses are happening at joints (such as Flywheel or Ring and pinion), transmission and differential. Today's high performance cars have much more efficient drivetrains than 10 years ago. For example DCT with two separated clutch is more efficient than a single clutch and that's why they even offer better fuel consumption. Why do you think ZF is claiming 20% better fuel economy? The same thing with differential and the other parts. On the other hand in case of M5, I have seen bunch of Dyno numbers claiming 520-540whp. Considering 15% drivetrain loss, the crank would be somewhere between 610-635 HP. I admit the power of S63tu is underrated by BMW but not this much. IND was one of the first one measured 527 whp. Considering 12-13% drivetrain loss, the crank would be ~600 HP and it makes sense to me...
You can read this article:
http://www.torquenews.com/106/2013-b...wer-advertised
      10-21-2015, 09:18 PM   #15
devondragon
Interesting. This article - http://www.automobilemag.com/feature...rs4_dyno_test/ talks about 20% loss for AWD. I know RWD has more loss than FWD, so 15% makes some sense to me, but yeah it does mean the crank HP is pretty high. I could just be being optimistic hoping to have more power than I do though
I just found this - http://www.***********.com/showthrea...ion)-vs-Manual
which seems to state clearly that DCT has MORE loss than manual. Performance and fuel economy being gained by quicker shifts and higher gear ratios. I dunno.
      10-29-2015, 08:31 PM   #16
Msizzle
Drives: 2013 M6 Coupe
one major flaw i find with drivetrain loss is the fact that we use a %. If each component robs X amount of hp, which is basically the power it takes to turn or move that component. Using a % infers that this loss would increase as power increases and that its not the case. If the car has a loss of about 75hp when it is stock and you then get a tune that adds 100bhp by using the same % you are saying the loss is now more than 75hp. Why would the amount of power needed to move the components increase just because the power increased?
      10-30-2015, 12:07 AM   #17
devondragon
Well some of the loss points DO change based on how much power/torque is pushed through them, (added heat, more stresses, etc...). Actual losses will vary based on RPM, drivetrain load, component temperatures, etc... so it's really a ballpark range anyhow.
FWIW I've found several sources that show automatics typically show 2-5% higher loss than manuals, and RWD loss range from 10-18%.
