      09-19-2016, 02:49 AM   #1
Aussie_Bimmer
Drives: BMW X5
373M wheel question
Hi All
My GC has the 373M wheels. I purchased the car used from a BMW dealer. When I first got the car, after noticing bad vibrations, BMW replaced two of the rims (one front and one rear) due to them being buckled.
I today went to an independent tyre shop to get another balance done (as slight vibration exists) and interestingly the technician said one of my rims has a different offset than the other three (he said around 15mm?). He also said the rim had a similar part number on the inside but with 15 on the end. All other 3 rims went on the balancer ok but obviously the odd one required a different adapter (sorry not sure if the exact terminology).
I went back to BMW and they will look at on Wednesday. However my question is;
1. Do true OEM wheels have the part stamped on the inside of the rim and if so where? Should they be stamped with 36117843715 for the fronts and 36117843716 for the rear?
2 Is it possible I have purchased a car with replica rims and when BMW replaced two rims one had a wrong offset? Do the 373M style rims come on any other BMW with a different offset?
      09-20-2016, 12:37 AM   #2
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
yes, will be stamped on the inside of the wheel. see here
http://www.ebay.com/itm/20-BMW-640i-...1XtPX9&vxp=mtr
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      09-20-2016, 08:10 AM   #3
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
Originally Posted by PaulJames View Post
Hi All
373 M wheels are a staggered set - so two wheels should be different than the others. rears are 1/2" wider and take a different size tire. You can easily look up the offsets. And yes - BMW stamp with wheel width and offset will be on the inside of one of the spokes.
