      08-27-2023, 07:51 AM   #1
cdog2964
Drives: 650i Xdrve
50k mile service and tire wear question
Well, my wife talked me into keeping my 2014 650ixdrive convert, says it a great date night car, but that also means i have to perform the 50k mile service which i think is a big one. Aside from the obvious, Oil change, Spark plugs and tire rotation, should i do anything else? Trans fluid change, coolant, etc?
Also, im getting odd tire wear on the inside of the two front tires. Basically its wearing on the inside part of the tire edge much faster than the rest of the tire and that seems to be a trend given thats why i had to replace the two from tires about 20k miles ago. They aligned it when they replaced the tires, done by the dealership, and its been aligned several time prior to me owning it according to car fax. Is that just normal for these xdrive cars, or do i have another issue besides alignment i need to look into?
thx
      08-27-2023, 12:29 PM   #2
Qsilver7
Qsilver7's Avatar
There should be a maintenance/service booklet in your owners manual binder, too…that can give you an idea of what services to perform based on mileage.
      08-27-2023, 03:12 PM   #3
Opie55
Drives: '15 650i Convertible
thx
I do not have unusual inner front tire wear on my 2015 XDrive convertible at 54,000 miles. You must have either a toe or camber issue. But before getting another alignment, I'd get a competent person to check all your suspension bushings. The oil-filled bushings on the large arms way at the front are often failed/leaking by 50,000 miles.
      08-27-2023, 07:03 PM   #4
cdog2964
Drives: 650i Xdrve
Yes, i understand the normal maintenance schedule, but my question is since the car has been sitting so long with not a lot of miles put on it, should i consider accelerating the fluid changes and not wait another couple of years until i have the correct amount of miles on it to do the scheduled maintenance?
      08-27-2023, 09:07 PM   #5
Opie55
Your question didn't say anything about the car "sitting so long." And we don't know what that means even now. I have a one year newer car with similar miles, and at no point would I say it has been "sitting." At or around 50k I did plugs, tranny fluid, front and rear differential fluids and transfer case fluid. But that's just me - I didn't do it because of sitting or any other reason. 50k is just a nice round number, so I celebrated it. I still have not changed the coolant. Maybe someday I will.
      08-28-2023, 03:35 PM   #6
Qsilver7
Qsilver7's Avatar
...Aside from the obvious, Oil change, Spark plugs and tire rotation, should i do anything else? Trans fluid change, coolant, etc?
thx
...since the car has been sitting so long with not a lot of miles put on it, should i consider accelerating the fluid changes and not wait another couple of years until i have the correct amount of miles on it to do the scheduled maintenance?
If the car is running great with no issues...and you do plan to keep it...and you have the funds...then why not. Treat her to a "spa day". Everything you mentioned would fall into the "good measure" category.
I would throw in one more fluid change that wasn't mentioned...and that would be to change your brake fluid. Brake fluid is hygroscopic (absorbs moisture) which degrades the brake fluid's effectiveness. It should be changed on a 2-3 year interval.
      08-28-2023, 05:06 PM   #7
cdog2964
Drives: 650i Xdrve
Awesome, thank you. Exactly the info i was looking for.
Thx again
