      03-20-2019, 12:50 PM   #1
65lim
65lim's Avatar
Drives: 2013 F13 M6, 2011 E92 M3
Front driver side clanking/rattling noise
Hi, I first heard the clanking noise from the front driver side wheel/suspension about a month ago when I was driving on an uneven surface. The clanking noise has been getting worse since then. I did some research and found that wheel bearing might be the problem, so I replaced the wheel bearing along with the hub. After i changed the wheel bearing the clanking noise is still there, any idea what it could be?
Here's a link to a video:
https://www.dropbox.com/s/6epsq2jyjw...%20AM.mov?dl=0
Thank you.
Current: 2013 F13 M6 | Singapore Grey Metallic on Sakhir Orange/Extended Black Merino | Bootmod 3 Stage 2 | Dinan Free Flow Exhaust | M-Performance CF Rear Diffuser | Charcoal Filter Delete BMC Replacement Air Filter |
Current: 2011 E92 M3 | Alpine White Grey Metallic on Black Novillo | AlpineMSS Stage 2 Tune GTS DCT Tune Euro MDM | Rogue Engineering Testpipe ACM Muffler Mod | M-Performance CF Front Lips | BMC Replacement Air Filter |
Retired: 2011 F10 535i | Carbon Black Metallic
      03-20-2019, 06:08 PM   #2
BMWDriverX
Drives: G12 750i X-Drive
Maybe the strut, or one of the suspension bushings up front. Sway bar bushing, etc.
      03-21-2019, 04:00 PM   #3
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Holy sh...t that sounds horrible. But I would go with SoCal6GC. Struts, bushings damper.......
      03-22-2019, 12:59 PM   #4
65lim
65lim's Avatar
Noted! Thanks
      03-22-2019, 01:00 PM   #5
65lim
65lim's Avatar
I know right..
      03-07-2021, 08:08 AM   #6
Bartek.b3d
Bartek.b3d's Avatar
Poland
Drives: BMW 640i F13 (LCI)
Hello,
Did you find a reason for your issue? I have similar rattling noise in my 6. Service suggests It could be front struts, but they are not sure about it.
Regards,
Bart
      03-07-2021, 12:48 PM   #7
65lim
65lim's Avatar
Originally Posted by Bartek.b3d View Post
Hello,
Regards,
Bart
So i changed the strut mount and tension strut arms on my car. The clunking went away, hope it helps!
Tags
bmw, clanking, rattle, suspension
