Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      07-18-2014, 10:48 AM   #1
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
PSI M4 Visits CCW for Extreme Wheel/Tire Fitment Testing!
Knowing that a custom forged wheel company is local to us, it would be nearly criminal not to bring our new BMW M4 over and try on a series of different wheels and tires to find out the maximum we could run - especially in the rear. At CCW (Complete Custom Wheels) here in Central Florida, our goal was to find out how far we could push the sizes and fitments without any rubbing or having to roll the fenders.
CCW is a one-stop shop when it comes to custom forged wheels - nearly every part of the design and manufacturing process is done under their roof. This approach, along with their direct sales to the public, allows for almost unlimited fitment options and very low lead time. We took the liberty of touring their production facility and grabbed a few photos to share with everyone here.
After several combinations were installed, including a few pairs of wheels off the shelf, we were able to fit a 19" x 11.5" 325/30/19 in the rear! We also compressed the rear to simulate fitment with coilovers. This helps to produce the best sizes for each customer's unique preference and use of the car (street/track).
Enjoy the photos!
Let the fitting begin!
      07-18-2014, 10:52 AM   #2
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
Not a big fan of the wheels, but the shop looks awesome!
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      07-18-2014, 11:00 AM   #3
Sean@PSI
Sean@PSI's Avatar
All the setups pictured are for size testing only. We are not running any of the wheels pictured here.
      07-18-2014, 11:06 AM   #4
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9571
Drives: G82 M4 / G87 M2
Good stuff guys!
What sizes did you come out with? These new cars can fit an incredible amount of wheel and tire right from the factory.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      07-18-2014, 11:22 AM   #5
Damasconian
Damasconian's Avatar
742
Drives: 2015 M4
Im in the oilfield business and tour factories all the time. Most of them have lathe's that cost hundreds of thousands of dollars, usually coming from Japan. I am so impressed there are companies in the US that invest that kind of money into quality automotive products.
I cant say how impressed I am with the shop.
And bravo to you guys for buying the SO color. While I still havent seen it in person, your pictures were enough to get me to change my order from SB to SO. Keep them coming.
      07-18-2014, 11:24 AM   #6
Sean@PSI
Sean@PSI's Avatar
Originally Posted by Ilia@IND View Post
Good stuff guys!
Those last pics are of a 19" x 11.5" 325/30/19. We tested this crazy sizing just to find out the maximum we could run in the rear.
It will be somewhere close to that once CCW finalizes our set for the M4.
Once they are on I'll post the sizing CCW decided on.
      07-18-2014, 11:27 AM   #7
Sean@PSI
Sean@PSI's Avatar
CCW is a serious manufacturer of 100% custom wheels, which is why we took the time for this visit. If they didn't have a size we needed on hand for our fitment testing - they MADE IT on the spot.
Thank you! - New photos are always in the works!
      07-18-2014, 11:29 AM   #8
///M ARMY
Drives: F90
i knew 11.5 in the rear wouldn't be an issue. A 325 is nice. I plan on running a 305 in the rear.
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      07-18-2014, 12:12 PM   #9
qwickm3
Drives: F80 M3,997 Turbo, Spec E46
Are they making 1911 frames for themselves or for someone else?
      07-18-2014, 12:18 PM   #10
Myrder
Myrder's Avatar
Drives: 2010 E92 335i MSport 6MT LMB
Those are some fat tires on the back...I like it. The style wasn't bad either, though more american than euro.
Can you share why they had CnC'd some handgun frames? lol
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56|
-I will look on your treasures, gypsy. Is this understood?-
      07-18-2014, 12:57 PM   #11
Myrder
Myrder's Avatar
Originally Posted by Sean@PSI View Post
I believe those are tests for a local manufacturer of 1911s. - Just shows the intricate work the CNCs can do.
Very cool. CCW makes some of my favorite wheels.
      07-18-2014, 01:11 PM   #12
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Was any testing done to determine the max fitment for FRONT wheels & tires as well?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      07-18-2014, 02:52 PM   #13
E92TRUTH
Drives: automatic
CCW makes some top notch wheels!
      07-18-2014, 02:59 PM   #14
Sean@PSI
Sean@PSI's Avatar
Yes, absolutely. That will be released with our CCW set on the M4.
I do know that my rear Volk TE37 SL (19 x 10.5 et22) did fit fine in the front.
      07-18-2014, 03:11 PM   #15
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Great news! Keeping the stock adaptive dampers (and adding in camber plates), what sort of max tire size do you think will be possible up front? 285?
      07-18-2014, 04:23 PM   #16
tightie
JOSH SHOKRI.
tightie's Avatar
Drives: 991 GT3RS, 964, Raptor
2008 BMW M3  [7.90]
that is a meaty tire!
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict
      07-18-2014, 04:32 PM   #17
Money2536
Money2536's Avatar
1586
Drives: '13 E92 M3 | 992 GT3 Touring
This is great stuff Sean. You guys are doing an awesome job with this version of the car. This means we'll have no problem getting 305 AD08R on my car. This is good news for the driving skill challenged 6MT guys like me. Meat on the tire with some sidewall equals much less wheel spin and less skill required to get the car off the line!
      07-18-2014, 10:56 PM   #18
Vectors2final
Vectors2final's Avatar
Drives: 2018 F80 YMB/SS ZCP
You are my hero... I plan on calling/emailing Dan in the spring and I might not have such a hard time getting fitment guidance now! Awesome!
I'm staying 18''. I have had a couple sets of LM-20s... I just love them.
EDIT: I am excited to see your setup... I'd like to run 305s out back, but I wasn't sure if it was feasible. Definitely seems like it is.
      07-18-2014, 11:40 PM   #19
donovan
donovan's Avatar
Drives: R8 - Ford Raptor
Nice shop,car and jack.
..good test wheels, lets make some that really give this m4 some justice!
Audi R8 v10
Ford Raptor
m3e46freak@yahoo.comfor all euro parts!!
ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum
      07-19-2014, 12:39 PM   #20
modkrazy
modkrazy's Avatar
171
Drives: m3
Holy balls!
      07-19-2014, 03:00 PM   #21
GrussGott
GrussGott's Avatar
Drives: 2018 M4 Comp Indv
Yeah, I kinda like it ... looks pretty racy ... I'm liking that wheel style better than the TE37s on the car, kinda looks like the VRG2 ... getting closer
Volks:
Originally Posted by TurtleBoy View Post
He tries to draw people into inane arguments, some weird pastime of his.
      07-19-2014, 03:04 PM   #22
Sean@PSI
Sean@PSI's Avatar
Yes, even 295 depending on tire manufacturer.
Tags
bmw, ccw, precision sport, psi, wheel
f80post
