01-22-2021, 02:21 PM | #1 |
Drive slow
Rep 26
Climate Control Cut off
My climate control in my 2014 F06 has stopped working, there isnt any function or lights. Everything else works fine. Should I check fuse?
01-23-2021, 11:55 PM | #2 |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
Have you had any aftermarket electronics installed recently? Checking the fuses would be the easy low hanging fruit to go after first.
01-30-2021, 09:00 PM | #4 |
630
Rep 1,171
Drives: F06 M6
in the glove box.
01-30-2021, 10:20 PM | #5 |
Rep 631
There is a fuse diagram in the rear /trunk fuse panel.
See the attached copies.
F06 M6 Grand Coupe CP
01-31-2021, 10:46 AM | #6 |
Rep 7,489
If one can’t understand the icons on the fuse index sheet...note that the icons on the sheet matches the icons on the button & switches inside the car as well as the owners manual.
FlyinLowSD35.50 |
02-01-2021, 07:33 PM | #8 |
Rep 280
10-14-2023, 08:12 PM | #9 |
Rep 29
Was there ever any update to the fix for this? Currently experiencing the same issue on my ‘16 F06 M6. Randomly started car and no power to climate controls nor the radio buttons. Radio still comes on with the steering wheel controls.
10-16-2023, 05:45 AM | #10 |
Rep 29
Update- Disconnected the battery for about 20 min, reconnected and all is well. Climate and radio controls are illuminated and regained functionality. Not sure what caused my issue.
10-16-2023, 08:13 PM | #11 |
Rep 631
Electronics gremlins are common when you try to start on a low battery.
10-25-2023, 08:12 AM | #12 |
Rep 29
