      01-25-2019, 02:05 PM   #1
Texas83
Drives: 650i Convertible F12
which fuse controls outlet charger in center armrest?
hello! trying to isolate my battery drain issue. I have the attached fuse diagram, but can't tell which fuse powers the car-charger/outlet adapter that's inside of the middle armrest (likely going to need fuse for outlet underneath passenger foot well as well). anyone have an idea which fuse it is? or has access to a better diagram that explains what each fuse is with words instead of tiny pictures? thanks in advance y'all!
      01-25-2019, 09:35 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
note that if there is nothing plugged into the lighter, then it is not the source of the drain. The only way they can consume is if there is a dead short. They are directly to the switched hot 12V line (KL30) line. I do not have the exact fuse, but hopefully this reference can help you out. There are various diagrams. Just type in what you are looking for.
https://www.newtis.info/tisv2/a/en/f06-650i-cou/
Good luck
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
Texas8315.00
      01-26-2019, 03:07 AM   #3
Qsilver7
Qsilver7's Avatar
Based on the chart you posted...the icon near the far bottom right that also has LIGHTER written below the icon...lists 54, 65, 108, 147, 176. These are the fuses that power the car's 12 volt sockets.
If you take that info & use the link given above to the TIS webdite...enter your car's VIN then type Fxx (where x= the fuse numbers from your chart) into the search box...you'll get links to the wiring chart that'll show which socket that fuse powers.
Texas8315.00
      01-26-2019, 10:11 AM   #4
jdsaengine
jdsaengine's Avatar
Drives: 2013 650iX vert, 2017 Corvette
2013 650x. had a penny drop down inside the glove box socket and blow the fuse. Its #54 fuse behind the glove box, 20amp.
and many thanks ARUCANO for that link, great info, I've book marked it
Texas8315.00
      01-26-2019, 02:45 PM   #5
Texas83
thanks y'all I will start my trial and error to see if I can isolate the drain source
      09-23-2020, 08:05 AM   #6
Adennard58
Drives: BMW 640I M-Sport Grand Coupe
I'm having issues with my center console and coin pocket cigarette lighter not working. I blew both fuses. The infamous coin falling in the coin pocket socket. I have a 2015 BMW 640I M Sport and I checked #54 and that fuse was good. So I will check the trunk fuses according to the diagram 108, 147, 176. I'm leaning towards 147 being it is a 20 amp. and the other two are 10 & 15 Amp fuses.
      09-25-2023, 03:22 PM   #7
dream54ing
dream54ing's Avatar
Drives: 428xi F32- X5 X5 G05 -640i F06
old thread, but have anyone figure out which fuse is for the USB outlet. I followed the above and none of the 108, 147, 176 were blown.
      09-26-2023, 02:22 AM   #8
FlyinLowSD
Tinker
Drives: 2017 640i GC,1994 300ZX MT 2+2
Try searching newTIS as described above.
      09-26-2023, 09:57 AM   #9
Qsilver7
Qsilver7's Avatar
We need more vehicle info to be of help. Which USB outlet are you asking about...you didn't give a model year or build date...and some have a USB outlet in the glove box, and one in the center armrest...and do some have one in the front cupholder?
      09-26-2023, 10:47 AM   #10
dream54ing
dream54ing's Avatar
its the usb in the armrest, none in the glove box or cupholder. 2015 640i gc.
