09-08-2023, 05:31 AM | #1 |
Rep 5
F06 Grand Coupe Front crash sensor location
Hi Guys,
I have a 2013 F06 640i and lately I'm getting an intermittent error of the front crash sensor. My E63 before had this one on the front bumper beam but I cant find it on this F06. Can anybode help please with its location ? Thank a lot. |
09-08-2023, 04:47 PM | #2 |
Rep 7,532
The only crash sensors in the "front bumper" are for the pedestrian protection system. If that is what the warning is for...see the info below. The intelligent safety system uses the KAFAS camera(s) and sensors in the rear bumper. Again, I'm not sure if the info below is what you're experiencing...but its a start.
09-10-2023, 06:26 AM | #3 |
Rep 5
Hi QSilver7,
Thank you very much! Yes I have found these but the fault code is from a different one. Should be somewhere on the front chassis part according to ETK but dont know the exact location..It should be the sensor with partnumber: Sensor, front Part number: 65779224176 I have found these in ETk an dthe sensors you have shown in the same category: 65 but it doesnt show the exact location. Any further suggestions please ? |
09-10-2023, 07:48 AM | #4 | |
Rep 7,532
I was originally looking for info that was associated with the intelligent safety systems that were associated with external obstacles…but again, the part number you gave is associated with the airbag system which is working with interior safety in deploying airbags if involved in a crash. The part number you gave are acceleration/deceleration sensors located on the left & right side of the…they appear to be located near the horns (H2 & H3)… which are located a bit further back…and not directly mounted on/in the bumper. See #4 in illustration from part database: https://bimmercat.com/bmw/en/search/...0i/USA/65_2262 FUNCTIONAL DESCRIPTION
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-10-2023 at 08:30 AM.. |
09-28-2023, 03:29 AM | #8 |
Rep 5
Hi Guys,
A follow up on this topic. Yes I found them, replaced a connector and how to check the pin diagram and the cable colour ? I was able to put the connector both sides in. Seems it was repaired before me. Thanks a lot |
