      03-17-2023, 03:21 PM   #1
Cincinnatus
Drives: 2013 M6
Would 21" X5 Rims Fit on F13?
I like the look of the 21" X5 Rims and there are a number of pre-owned sets at a decent price for those of us who can't afford HRE, Vorsteiner or other aftermarket options. Would a set these work on an F13 M6?
      03-17-2023, 05:45 PM   #2
Qsilver7
Qsilver7's Avatar
Not enough info to give you an answer. Which X5 generation or what is the BMW wheel style name/nbr.?
All of the wheels’s specs are needed to determine if they will fit. What is the offset, wheel bolt pattern, center bore, and width?
Run/compare your existing wheel/tire specs with the 21” wheels you’re considering at this site: www.willtheyfit.com. Compare the existing front axle to the new front axle setup…then do the same for the rear.
Again, find out what generation X5 the wheels come from. If they are from the G chassis X5…then they have a totally different wheel bolt pattern (5x112mm) and hub size/center bore (66.6mm). The f15 X5 wheels have a 74.1mm wheel hub/center bore.
The f06/f12/f13 six series wheels have a 5x120mm wheel bolt pattern and a 72.56mm wheel hub/center bore.
      03-18-2023, 07:43 AM   #3
Cincinnatus
Drives: 2013 M6
Got it, thanks!
      03-18-2023, 09:39 AM   #4
JDMSteven
JDMSteven's Avatar
Drives: '13 F13 M6, '94 JDM Supra
2013 BMW M6  [10.00]
Them suckers are WIDE, 11.5" in the rear.
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents
      04-13-2023, 01:00 PM   #5
NYBulldog
Specialist
1310
Drives: Nikes
M6 F13
10,5JX20 ET:19
9,5JX20 ET:31
X5M F85
11,5JX21 ET:38
10JX21 ET:40
REAR
Inner Clearance: 32mm LESS
Outer Position: RETRACT by 6mm
FRONT
Inner Clearance: 15mm LESS
Outer Position: RETRACT by 3mm
Seems like a 20mm spacer all-around would make them work.
