      01-12-2024, 11:35 AM   #1
IceScraper
Drives: BMW M6
Anyone know the best way to keep the Stock Exhaust Flaps Open?
Does anyone know how to keep the Stock Exhaust Flaps Open without a tune?
I've seen people drill holes, and screw them open permanently.
I've also seen others pull fuses on newer models; I don't know if that would work in our case.
The Golf Tee trick doesn't work. I've tried.
Thoughts?
      01-12-2024, 06:02 PM   #2
danielgmanm6
danielgmanm6's Avatar
Drives: 2013 BMW ///M6 F13
2013 Bmw M6  [0.00]
  [0.00]
  [0.00]
I know you can do it through bimmerlink but you need to open the flaps each time you get in the car. Not sure why it doesn't disable it entirely. I would get with f10 forum if you don't get answers here. A lot more m5's were sold haha
      01-12-2024, 08:36 PM   #3
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
I’m from the F10 M5 side. Many have done the mod and it’s worked flawlessly for years. Easy mod. Good luck.
https://www.bimmerpost.com/forums/sh...php?p=17126472
      01-13-2024, 07:18 PM   #4
peoe
Drives: 650 Grand Coupe xDrive
I've used the zip tie method shown in the link from Blaxwil (but with a zip tie). It worked well, but I ended up removing it due to too much droning.
      01-17-2024, 10:03 AM   #5
IceScraper
Drives: BMW M6
Thanks All!
I am going to try this first.
I've heard that with the MHD plugin, you can tune it out. I may eventually go that route.
