10-06-2017, 03:22 PM | #23 |
Rep 56
before i exchange my wheels i am thinking to replace my wheel hubs which are 7cm width with the m6 /m5 ones which are 4.5 cm. the m5/m6 are smaller by 2.5 cm.
first image is the 640 wheel hub and the rest the m5/m6 wheel hub. the only problem is that the abs ring on the up of the m5/m6 hub is not identical with the 640. anyone knows if this mod would be a possible solution? |
10-07-2017, 01:39 PM | #24 |
Rep 190
Drives: 2018 Alpina B6 GC & 2019 M5C
Why not go with this suggestion?
2019 M5 Comp; 2018 Alpina B6 GC; 2019 M4 CP (gone); 2018 X3 M40i (gone); 2015 M5 Comp Pkg (gone); 2016 X5M (gone); 2013 650 xDrive Coupe M-Sport (gone); 2013 F10 M5 (gone); 2011 550i (gone)
10-07-2017, 08:03 PM | #25 |
Rep 11,128
Flying Ace4982.50 |
10-08-2017, 04:10 AM | #27 |
Rep 209
I really like the hub idea. Just having a look on realoem.com and the wheel carriers are obviously different but the abs sensor might be something you could modify. Why settle for something less than what you're after..
Might be something that could be fabricated using both parts. |
10-08-2017, 05:14 AM | #28 |
Rep 209
Looking at the pictures again, I can't see this working. There is a significant flange on the M6 hub that would fit into a recess in the M6 wheel carrier. Where as the standard hub has little flange. Looks like the bearing in the M6 hub is within this flange and hence the hub carrier bolt holes are so shallow to the outer part of the hub. From these pictures it looks like you'd be replacing the wheel carrier and all of the rear suspension for M6 components, or a modified wheel carrier but not sure how much I'd trust a part where metal has been removed (as in creating a recess in the wheel carrier to accept hub). You'd probably run into issues in the length of the driveshaft as well.
10-10-2017, 12:24 PM | #30 |
Rep 3,477
10-11-2017, 04:09 AM | #31 |
Rep 56
11-08-2017, 11:42 PM | #33 |
Rep 56
new bmw m5 601m alloys with oem m5 sizes installed.
Flying Ace4982.50 |
11-09-2017, 12:10 AM | #34 |
Rep 239
Good choice....about 2 months and a lot of unnecessary headaches too late but it looks great.
2014 BMW 650GC M sport
2011 BMW 550i M-sport/AW 1991 Nissan 300ZX Twin Turbo 2007 Chevrolet Corvette Z51 (sold) 2001 BMW 325ci (sold) |
