      04-01-2014, 02:17 PM   #1
GannyCy
Drives: 2014 640i Gran Coupe
Low Dust Brake Pads
Anyone changed out their pads for low dust pads? If so, which ones? I have a 2014 GC and get a lot of grey colored dust on my Liquid Black wheels that I would like to reduce. The dust is easy to remove during normal washes but I find it unsightly.
      04-02-2014, 07:40 AM   #2
GreyCoupe
Drives: 15 650i Coupe
All the German manufacturers love dusty brake pads...
Enjoyed some fun cars over the years: 1966 Corvette Convertible, 240Z, E24 L6, 300CE-24, 2004 645 Ci, 550SL, A6s, 535xi, E300/Bluetec/420, Grand Cherokee Overland, 2012 650i Coupe, 12 CL550, 13 SL550, 15 650i Coupe
      04-02-2014, 01:42 PM   #3
southern6er22
Southern6er22
I'd consider spending $8k on carbon brakes if it meant I never had to wash a rim again.
The front wheels are really bad, but there's not much that I've heard of that can be done.
      04-02-2014, 10:56 PM   #4
neversummer78
neversummer78's Avatar
Drives: 4 wheels....
I use Armor All Wheel Protectant and it helps quite a bit, but some reviewers said it leaves white residues on black wheel.
      04-03-2014, 07:51 AM   #5
GreyCoupe
Creating dust is an inherent by-product of disc brakes.
Brake dust production is determined largely by the ingredients in the pads themselves. There are pads that dust heavily (such as most German manufacturers favor) and others that dust relatively little. Some dust pads and rotors shed dust that clings to wheels more than others. Some pad compounds mix in greater amounts of hard materials, including metal. Different pad compounds yield different braking characteristics, may affect ABS, pad longevity, pedal feel, rotor wear, noise, etc.
As OP points out, changing out your factory pads for a set that make less dust can indeed make your brakes soil your wheels more slowly and less noticeably. You have to determine whether you like the different braking they offer.
      04-03-2014, 05:42 PM   #6
zoltans4
Drives: '14 650 coupe
more dust is softer material that (usually) is better at stopping, but doesn't squeak normally, doesn't ruin rotors and gives you more linear braking
less dust is often from hard material that (usually) is not as good at stopping but rather creates little dust and last a long time, can often give you a more 'instant' feel of braking at the top, subjectively that will be liked more to some than others.
there are some exceptions I am sure. I forgot which but I used to use an Aussie pad I beleive that was great for braking and low dust. Since BMW changes my brakes, they can put on whatever they want... I wax my wheels with a spray cleaner wax and it helps keep dust from sticking.
      04-03-2014, 05:59 PM   #7
GannyCy
Do you have an estimate as to when (mileage wise) BMW would change the brake pads as part of the 4-year 50,000 mile included service? Also, how many times would they likely replace them in that 50,000 mile window?
I might be better off waiting until the 4-year 50,000 free service has expired before I replace the pads with low-dust pads.
      04-03-2014, 07:39 PM   #8
zoltans4
As far as I know they will replace them as many times as they need to, which probably wouldn't be likely more than 2-4 times
      04-04-2014, 05:40 AM   #9
Bönz
Bönz's Avatar
Drives: 2018 M5
BMW replaces the pads when the cars tells them to. There are electronic sensors on each caliper. When the pads wear, they get replaced. It depends 100% on how often and how hard you use your brakes. As z4 said, no limit on replacements. The service reminder even provides an indication of when replacement is required. I'm not sure of the accuracy.
      05-29-2014, 10:40 AM   #10
GreyCoupe
Word is that BMW has changed to less dusty pads with 15 MY.
      05-29-2014, 11:53 AM   #11
GannyCy
After about 2,000 miles, I starting noticing less and less brake dust on my 2014. Due to this reduction I am no longer contemplating changing the pads. Has anyone else expierenced a reduction in brake dust?
      06-18-2014, 10:12 AM   #12
Boss330
Boss330's Avatar
EBC Redstuff pads should be good on both dust and brake performance.
