      01-14-2014, 06:00 PM   #1
LSM
LSM's Avatar
Drives: 2024 Porsche 911 GTS Cab
for those running aftermarket 21's on M6 - Proper size tires for 21's
21x9.5 fronts and 21x11 rears...I know people go with 265/30/21 fronts and 305/25/21 rears but if you go with the 295/25/21 rears the overall diameter and revolutions are more similar..Thoughts?? What are you guys running?
Thanks
Lou
2024 Porsche 911 GTS Cabriolet
      01-14-2014, 10:40 PM   #2
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
You are good either way. I would go 305 in back. That is what I am running also.
My Thread:
      01-15-2014, 07:31 PM   #3
LSM
LSM's Avatar
Originally Posted by Hunter5179 View Post
You are good either way. I would go 305 in back. That is what I an running also.
Yea thats the dilemna, 305's fit 11" rear better but the 295's more closely match the overdiameter and revolutions
      01-15-2014, 08:17 PM   #4
johntclark
Drives: M6
Tires
The 305 matches better than the 295. Just check the specs of who your buying from. I don't think anyone but Michelin make the 305.
      01-15-2014, 09:29 PM   #5
RiverRunner
RiverRunner's Avatar
Drives: 2014 M6 Gran Coupe
My speedometer is over by 7%, so if the tire diameter is 7% larger, the speedo would be correct. Maybe worth checking on your car before worrying about matching the diameter.
2015 740i Sapphire Blk/Blk
2018 Tahoe RST 6.2
2019 Porsche 911 Turbo 991.2
      01-16-2014, 11:21 AM   #6
LSM
LSM's Avatar
be close in overall diameter is important as are the revs per mile which is based on OD etc....Thats why I was wondering.
265/30/21 - overall diameter 27.3 - revs per mile 762
295/25/21 - overall diameter 26.8 - revs per mile 776
305/25/21 - overall diameter 26 - revs per mile 799
Stock
265/35/20 - overall Diameter 27.3 - revs per mile 761
295/30/20 - overall diameter 27 - revs per mile 770
      01-17-2014, 07:14 AM   #7
RiverRunner
Stock
I understand that, it's directly proportional to the OD/Speedometer, looks like the 305/25/21 will make the issue worse. Most of our Speedometers are off by 5-10%, (over). I was told that the OD is correct, and that the Speedometer has to be over to meet some European law. I think it's BS, they should make the it correct with new rubber, it will increase as the diameter decreases (RPM increases).
2018 Tahoe RST 6.2
      01-17-2014, 01:57 PM   #8
LSM
LSM's Avatar
Is it only the speedometer that is effected? I thought effected the traction control and other things?
      01-20-2014, 12:02 AM   #9
RiverRunner
My point is that the speedometer is off with the factory rims/tires, over by 7%.
2018 Tahoe RST 6.2
      01-21-2014, 10:50 AM   #10
LSM
LSM's Avatar
I got your point, I was asking another question thought you might know
      02-03-2014, 03:51 PM   #11
Tom@SonicMS
Tom@SonicMS's Avatar
Drives: M3
I think the 26" OD on the 305/25/21 is wrong. Its should be 27".
(305x25%)x2 / 25.4 + 21 = 27" which is closer to stock.
      02-03-2014, 04:37 PM   #12
LSM
LSM's Avatar
You are correct in that. When I was considering 21's it seems everyone on this board runs the 305/25/21 which is 26 OD. The better fit is the 295/25/21 which is 26.8 OD...
