05-15-2015, 02:55 AM | #1 |
Live for today tomorrow never comes
1989
Rep 9,498
Running in an M Engine
Interesting article on this here: From R&T Magazine.......
BMW is quietly rolling out a Customer Care Package, or CCP, for its N63 twin-turbocharged V8 to fix a handful of glitches that have plagued the 4.4L since it was launched in 2008. The CCP is not a recall since it does not address safety-related concerns. According to Road & Track, the CCP covers a wide range of items, from timing chains prone to failure to leaky fuel lines to faulty vacuum pumps. The CCP even reduces the N63's oil service interval from 15,000 miles to 10,000 miles. Interestingly, that reduction in mileage is the result of customers taking it too easy on the V8 rather than the other way around -- without a proper flogging during the break-in period, the N63 has a tendency to consume more oil. I have always (once Oil is up to temperature) Pushed the new "M" engines for the first 50 miles or so using lower gears to slow down, this has always resulted in No Oil used., looks like I was right. __________________
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
05-15-2015, 11:42 AM | #2 | |
Rep 232
Drives: 2016 M6 Gran Coupe MT
05-15-2015, 12:29 PM | #3 | |
1989
Rep 9,498
05-15-2015, 02:04 PM | #4 | |
Rep 1,125
BMW makes no reference to the more aggressive approach. I wonder if this CCP will change their recommendations or is it more an issue with drivers not using the motor as it should be used. |
05-16-2015, 03:19 AM | #5 | |
1989
Rep 9,498
The idea is to seat the rings earliest to avoid Oil consumption and loss of power. It would seem BMW feel the need to "change things" IE: "service intervals" instead of saying "work the engine harder once all is up to temperature". This strategy saves them having prohaps blown engines through abuse.
05-19-2015, 08:23 PM | #6 |
Rep 31
just slightly over heat the motor by blocking the raditor. this is a old trick dating back to the 50s. seats the rings, causing lower oil usage and increaded hp/mpg
05-20-2015, 02:36 AM | #7 | |
1989
Rep 9,498
Not recommended IMO.
