      11-14-2016, 05:05 AM   #23
abstinent
abstinent's Avatar
Drives: 640i GC Xdrive M-Paket
Originally Posted by Almaretto View Post
USB updates are just for Bluetooth Media and Communication. Flash programming is required for other system. But, there are no release notes so you could gain improved performance or lose features.
Do I understand it correctly that the update of the "other" system is visible only once it is plugged in at the service? What you mean by "lose features"? thanks a lot!
      11-14-2016, 08:38 AM   #24
Sonny Crockett
Sonny Crockett's Avatar
Sweden
45
Drives: 640D X-drive M-sport
"Root directory of FAT32 formatted USB" - please explain what this mean?
      11-14-2016, 11:02 AM   #25
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You can check you map version. The head unit numbers will change. You can also check hidden service menu. Dealer does not have E-sys, they only have ISTA+ and ISTA-P. ISTA will show Integration or I-Step, which is firmware level for vehicle; E-sys will show this and more information.
Vehicles that had software from ISTA-P 3.58.3 or below and upgraded to next level 3.59.0 lost seat memory gong (ie the auditory confirmation of setting seat preference). But, those with LED adaptive headlamps also got improved parameters for a smoother system. As such, upgrading is a "crapshoot" because there are no release notes indicating changes and you could gain function enhancements or lose features.
Root directory means not within any folder of USB flash drive. For example, C:\ and not C:\update. There are different drive formats (NTFS, FAT32, etc). You can right click drive and select properties so see how it is formatted. If incorrect or undesired setting, then you right click and select format to change. Formatting will erase entire drive contents so you must place files after process.
      11-14-2016, 12:12 PM   #26
Sonny Crockett
Sweden
45
Maybe I understand, just for info I have a Mac..If I copy this to my USB and it still looks the same as my print screen it is correct?
      11-14-2016, 12:24 PM   #27
Almaretto
Almaretto's Avatar
2374
I have not touched a Mac in 20 years, so I cannot say for sure. Just make sure there are no hidden files or directories.
      11-16-2016, 01:46 AM   #28
abstinent
abstinent's Avatar
thanks a lot
      11-16-2016, 10:30 AM   #29
Almaretto
Almaretto's Avatar
2374
thanks a lot
      11-18-2016, 11:56 AM   #30
The0pportunist
The0pportunist's Avatar
471
Drives: F30 335i
Flash programming vehicle (ie ECU updating software/firmware) will update Bluetooth Communication and Media as well. The latest releases for NBT is the following:
NBT_N16094A: MN/TN-003.011.002 (ISTA-P v3.59.5)
NBT_???????: MN/TN-003_013_001 (ISTA-P v3.60.0)
Those are both newer than what is found on Bmw.com/update
From the map screen, select options > scroll to bottom > select version.
It will look something like:
North America
BMW Group
111152.3.111
Road Map NORTH AMERICA Next
2017-1
NBT_M15392A
Or, from Settings > Software Update, you can also select update or check version. It will look something like:
Veh. ID: Short VIN
Tel: TN-003_013_001
Media: MN-003_013_001
Thanks, so this is what im running.
Can anyone confirm if this is the latest version?
      11-18-2016, 12:09 PM   #31
sewright
Drives: 2013 650i
I just upgraded mine about 1-2 months ago.
Multimedia: MX-003.005.004
Telephone: TX-003.005.008
2013 650i - Imola Red
      05-03-2023, 03:32 PM   #32
6ixfitty
Drives: BMW 650i f13
Could you please email me this file ?!
