      08-06-2021, 11:42 AM   #23
tepelen
Drives: BMW X5
I know this is an old post, but I had the same issue. There is an article on Youcanic that goes over this problem in detail and explains the issue very well.
      02-06-2024, 08:00 PM   #24
xlr8tin
Drives: 2013 750li xDrive
Originally Posted by NorthCountryGuy View Post
The Guys at Cantech Motor Works in North Syracuse did a first rate job.
The vehicle’s malfunction and codes were speaking to a signal malfunction and not an actual hardware malfunction.
I’m pretty good with auto electrics, but I couldn’t solve it.
Even having ISTA, Mike (the SA) said it was a difficult case.
It ended up being a broken wire in the BUS of the crankshaft sensor circuit.
What I did find was a new found respect for the tenacity of the the tech of record in this case.
Case closed.
I have the exact same issue. It started with the transmission overheating. Many fixed and dollars spent later and it came back. I have all the codes you did.
You mentioned a broken wire. Were you shown the location or just told that you had one. I need to narrow this down for my mechanic since they can't figure it out
      02-06-2024, 09:44 PM   #25
Opie55
Drives: '15 650i Convertible
The person you are asking has not visited the forum in nearly four years.
      02-07-2024, 09:30 AM   #26
xlr8tin
That figures
