      08-06-2016, 07:38 AM   #23
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
M5 London: My bad, read it the other way around. It does add to the confusion.
M5 London341.50
      08-06-2016, 06:46 PM   #24
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Adding a quarter every 350 mils is not normal but for your reference I add a quarter almost every 1000-1500 miles and I drive my car the way M car is meant to be driven
      08-09-2016, 06:22 AM   #25
IM6
Drives: BMW M6 F13
BMW have really become below par part fitting service centers.
0-40W is the one ive been told by BMW.
      08-09-2016, 07:04 AM   #26
M5 London
342
Drives: F90 M5 LCI - Aventurine Red
From my BMW Parts guy who has previously supplied me with bits for all of my other ///M cars :
All well here thankyou, hope you can say the same.
It's actually this one we keep now '83212365929' priced at £15.56 per 1litre bottle to yourself.
LL04 0w30 only available from BMW dealers but made by Shell.
As you may be aware, BMW left Castrol for Shell due to their breakthrough gas-to-liquid technology.
F90 M5 LCI - Aventurine Red/Smoked White-E39 M5 - Modified ESS Supercharger Kit -E34 M5 1995 - Arctic Silver / Black Leather-
E30 M3 1987 - Diamond Black Metallic / Black Leather-996 Turbo - Lapis Blue/Savannah-VW Rallye Golf
      08-09-2016, 07:59 AM   #27
IM6
Drives: BMW M6 F13
Update:
Since the oil change as part of the investigation, I have just come back from Europe, 1200 miles round robin trip. The car since oil change/refill has done 1467 miles before the oil message popped up. Will book the car in for oil measure whereby they actually weigh up the oil.
I'm not sure how much of oil is actually consumed before it hits the minimum sensor? perhaps 2 litres?
One more problem I also been facing since purchased the car is the vibration in the steering at speeds over 100mph. I had the dealer look at it, they did the tracking but the problem still persists.
      08-09-2016, 08:25 AM   #28
M5 London
342
Well at least the oil consumption is moving in the right direction and by a factor of 4 !
Having said that motorway runs generally exhibit much lower oil consumption than stop start town driving....
      08-09-2016, 09:07 AM   #29
IM6
Drives: BMW M6 F13
I must thank all you guys for your input and help.
I need to write up a separate post for the vibration issue which has been there since I purchased the vehicle.
      08-09-2016, 09:26 AM   #30
M5 London
342
How about wheel balancing ?
Sounds very much like it to me.
      08-09-2016, 10:19 AM   #31
IM6
Drives: BMW M6 F13
Hi Mate
I have already done the balancing and tracking twice. Could be a bent alloy I suspect.
      08-12-2016, 10:28 AM   #32
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Hi Mate
Is it all the time or at braking? any specific speed?
I had the same issue and they replaced the rotors. Problem fixed for couple months and came back again... n that much but mine happened at speed over 80 mph while I slam on brake pedal
      08-15-2016, 06:04 AM   #33
IM6
Drives: BMW M6 F13
mine has nothing to do with brakes ( I hope so), the shudder/shimmy comes over 95 MPH
      08-15-2016, 07:50 PM   #34
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
So 674 miles and car asking for more oil. Parts Dept. gave me three bottles free this time. Also called BMW NA to complain, will post what they say.
      08-16-2016, 06:14 AM   #35
IM6
Drives: BMW M6 F13
Can you please state how are you driving the car?
      08-18-2016, 04:12 PM   #36
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
It is my daily driver. I always run in manual mode with dct set to three bars. My commute is 22 miles one way, with 2 miles at 45, 13 at 55-60, 6 at 70-80 and 1 at 30. I tend to drive relaxed most days, shifting at 3-4k in comfort mode. I use M2 occasionally, with sport plus set except steering.
      08-26-2016, 06:30 AM   #37
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
BMW, N.A. has agreed to have dealership check out my car regarding the oil issue. Will take in next week and report what they state.
      08-26-2016, 07:35 AM   #38
IM6
Drives: BMW M6 F13
MJ POSNER : this is what they did, simple thing, changed the entire oil with correct grade and new oil filter. Since then I have driven across 3 countries before it asked for top up. 1500 miles without top up.
      08-27-2016, 07:08 AM   #39
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
IM6, I had the oil changed at 32k miles. Now at 39k miles. The funny thing is per the Service Bulletin: "Due to the increased engine power, all Motorsport engines can consume up to 2.5 quarts of engine oil per 1,000 miles at any time." Based on that they can say my car is normal at 650-700 miles per quart.
http://blog.bavauto.com/16943/bmw-hi...-si-b11-03-13/
      08-30-2016, 09:42 AM   #40
IM6
Drives: BMW M6 F13
that's ridiculous and certainly abnormal.
Ive been told the tolerance is 1.5 ltres per 1000 miles. not 2.5!
      08-31-2016, 07:20 PM   #41
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
http://www.bimmerfest.com/forums/arc.../t-714085.html
My car is now past day three at dealer for this issue.
      09-02-2016, 06:49 AM   #42
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
Day 4 and still no word on my car. I wonder if they found something that was causing the oil use. I got a cryptic "maybe" for pick up today.
      09-02-2016, 09:48 AM   #43
IM6
Drives: BMW M6 F13
Good luck with the car, my car is being worked on for the last 3 days relating to the vibration issue. The dealer has been beyond my expectations and has gone out of its way to change the entire suspension components such as struts, lower suspension arm, wishbone. it is a long job. they have even authorised a free KDS which alone is £250.
Nothing better than picking up the car on Friday evening after work
      09-03-2016, 11:54 AM   #44
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
Picked up my car today, they want me to keep track of oil consumption and not add any oil. They will then see what BMW N.A. wants to do.
