      08-22-2016, 07:26 AM   #1
tab
Drives: 2016 M6 Gran Coupe MT
2016 BMW M6 GC  [10.00]
Gas Pump Shutoff
O.K., here's a minuscule thing: does anybody else have a problem with gas pumps (would virtually always be a Shell station) shutting off prematurely when filling the M6 GC? Like I know it's down to 1/8 a tank, it needs 18 gallons, so why does it shut off every few gallons? So I re-start it, because I know it needs more. Is it something about the shape of the filler neck? I've filled plenty of cars, and I don't think it's like I'm bad at this. It just seems to happen annoyingly frequently with my M6.
-Annoyed in Chicago
      08-22-2016, 08:40 AM   #2
Eurohorses
Eurohorses's Avatar
503
Drives: 23 Jahre G80 M3
-Annoyed in Chicago
Happens to me all the time, but not only with Shell. Happens at other gas stations as well. Shuts off multiple times before the tank is full. I find that holding the pump trigger half way stops this from happening. But then it takes twice as long to fill up.
I thought this only happened to me
      08-22-2016, 08:42 AM   #3
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
Same issue here. Gotta be something odd in the tank filler tube design that triggers whatever shuts off the pump handles? IDK but it is annoying.
      08-22-2016, 09:19 AM   #4
JakeBMW
JakeBMW's Avatar
12
Drives: 2016 650i Xdrive GC -Carbon Bk
I have a 2016 650i GC and have not had that problem.
      08-22-2016, 09:33 AM   #5
dentaltech
Drives: 2013 M6 coupe
If you push the nozzle to far in and the the rubber seal seals too tight it seems the there is splash back and the pump registers it as full (safety)
I do not push it too far into the curve of the filler neck and try and hold it more parallel to the inlet.
Its not a car you can jam in there lock the filler and let it run. Its a hold your hand baby it fill up and yes its a bitch!
      08-22-2016, 10:08 AM   #6
tab
O.K., it's nice to know i'm not crazy! I also do the thing where I put it on slow feed, and don't jam it all the way in. Still can be difficult. If that's the only bad part of my day, I'm doing fine, I know....
      08-22-2016, 11:21 AM   #7
Don N.
Does suck when it happens. That's why I always have to pay attention to roughly how many gallons I think my car needs, based on the fuel gauge.
      08-22-2016, 11:21 AM   #8
speedracerlo
Drives: 2015 M6 Gran Coupe
Been having this issue since day 1, but I thought I might be the only one in the world if I complained about such a thing... lol now I know
There seems to be a design flaw where the nozzle air suction cups don't align well to the M6 inlet.
      08-22-2016, 11:59 AM   #9
wanna6
Drives: .
Just got a 14 m6 gran coupe and I can report the same problem. Good to know it's not just me!
Will try to insert it halfway next time and hold by hand as a previous poster reported.
      08-22-2016, 11:53 PM   #10
2007 to 2016 M6 Cab
Drives: 2019 M2 Competition HS
Yes I see the same ... I never place the Gas Nozzle all the way in ... So it doesn't happen as often, but then again I do not squeeze the pump handle all the way either as I HATE WHEN GAS SPRAYS OUT AND ALL OVER THE PAINT
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV
Past Cars:
2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban
      08-27-2016, 02:31 AM   #11
S800vxr
Drives: F13 M6 Coupe
UK cars do this as well so I'm glad I've read this as thought my car was broken somehow!
      08-27-2016, 10:53 AM   #12
daddymalu
Drives: M5
I have taken my 14 coupe in for this issue and they said there was no trouble found.
gmd2003351.50
      08-28-2016, 12:26 AM   #13
Twitch Massacre
Twitch Massacre's Avatar
Drives: 2015 BMW i8
I12 BMW i8  [0.00]
F13 BMW M6  [0.00]
I had this issue on my M6, figured out an angle that would prevent it from happening 90% of the time. Move the nozzle around a bit and see if you can find an angle where it won't stop.
H&R Springs
21" ADV.1 ADVNL2 MV2 CS Wheels
Coming Soon:
2016 BMW M4 GTS De-Winged and Bagged on 22s
      08-30-2016, 10:30 AM   #14
doughboy650gc
Drives: 2013 650i grand coupe
13 650i gc had the car for 2 weeks and worry that I'm going to get sprayed back at some point
      09-17-2016, 10:21 AM   #15
tab
OK, now that I know I'm not crazy, I decided to try something. Last time I filled up, I put the nozzle in and turned it so the bottom of the handle was pointing down and to the right, like 5:00 position. (I would normally stand behind the fuel filler door and probably cock the handle between 6:00 and 8:00, without really thinking about it.) It didn't kick back. I'll keep trying that. I'm thinking there must be an angle at which it works. So far, I'm trying 5:00.
      09-20-2016, 06:08 AM   #16
Msizzle
Drives: 2013 M6 Coupe
13 m6 with same issue
      09-20-2016, 07:27 AM   #17
tab
OK, the next time I tried 4 or 5:00, it shut off. So I tried it cocked at an extreme 8:00 and it worked.
      09-30-2016, 10:53 AM   #18
doughboy650gc
just filled up last night and it didn't do it.. this happened to me the first 2 times I filled up it but now I refill when I hit the 1/4 mark and it doesn't shut off on me....
      09-30-2016, 01:00 PM   #19
skydavis
skydavis's Avatar
Drives: 2013 BMW M6 Convertible
Happens to me too
      10-03-2016, 08:17 AM   #20
XxTORONTOxX
Drives: BMW F13 M6
it happens when you have an empty tank, there is air in the tank which causes this. Try holding the nozzle at 90% force it will fix the issue
