12-17-2017, 09:07 AM | #1 |
Rep 2,138
Drives: 2011 E92 M3
Are 7 speed manual transmissions really needed?
So, IMHO, having 5 forward gears is plenty for 99.99999% of driving situations. This gear count used to work back when high strung engines put out 200HP. Now, we have cars with 400+ HP and we need 6 and 7 speed transmissions?
My first 6 speed was in a VW and I almost always skipped 5th gear as it was so close to 6th. I still dropped to 3rd to pass on the highway. Same is true in both my BMWs. I have never driven a 7 speed manual. Unless 7th gear is a big arsed over-drive, then what is the point? Discuss...
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
12-17-2017, 09:15 AM | #2 |
Rep 419
I know our F80 needs one badly, I mean I certainly dont enjoy cruising at 80 with the tach at 3K. A seventh gear overdrive that would put it back at 2K or even 2.5k would do wonders for cabin comfort NVH. That is my only gripe about our 6MT.
12-17-2017, 09:50 AM | #3 | |
Rep 573
how do you skip a gear? by mistake you switched to 5th? most cars need a cruising gear for highway use also the most importantly probably better MPG's. Is not like they're long gears either. |
12-17-2017, 10:28 AM | #4 | |
Rep 2,138
Drives: 2011 E92 M3
I agree that a highway gear would be nice. My E92 with 4.10 gears revs way to high at highway speed. On another note, I have never used 5th gear at a race track. Ever. The top of 4th in all my track cars has been fast enough. |
12-17-2017, 10:31 AM | #5 |
I'll get back to you
7556
Rep 2,132
What is this "manual transmission" you speak of?
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
12-17-2017, 11:29 AM | #8 | ||
11825
Rep 15,400
What the fuck are you on about?! And: You're doing it wrong.
12-17-2017, 01:03 PM | #9 |
Rep 419
Ummmmmm.... What am I doing wrong?
Go on your nearest highway speed up to 80 mph on 6th gear and come back and report what your tach reads. The gear ratios on this car were optimized for track performance not highway cruising. That's just one of the compromises made. Hence, it would be nice to have a 7th overdrive gear. |
Lups11824.50 |
12-17-2017, 01:17 PM | #10 | ||
11825
Rep 15,400
I should know. In one year and four months I drove through usa and Canada a few times in one. My answer was bitchy, I'm sorry. If this thread was about dropping a gear I'd be as bitchy but adding one would change the character too in ways i have to object to!
12-17-2017, 02:06 PM | #11 |
Hoonigan
6816
Rep 3,000
Drives: '09 328i, '98 Wrangler
7 speeds? At what point does it stop being a BMW and becomes a semi-truck?
I love driving manuals, but driving around other people in high traffic areas really pisses me off sometimes. Nothing like having to slam on the brakes because of one idiot driver, row through all the gears, and have to do it all again 30 seconds later because someone pulls out in front of you and stops. On a twisty back road or less populated area? Manual all the way. With today's drivers who are constantly distracted it makes any kind of driving not as enjoyable unless you are in the middle of nowhere. When I commuted into the city I probably had one or two close calls with other idiots on a daily basis.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
Lups11824.50 |
12-17-2017, 02:10 PM | #12 | ||
11825
Rep 15,400
12-17-2017, 03:11 PM | #13 | |
#buildnotbought
10626
Rep 4,848
However BMW's are german cars. I dont know if you've ever been to Germany, but cruising on the autobahn at 100-120mph for longer stretches is quite normal, especially in the more rural areas and with a high performance car. And then with the modern engines that provide huge amounts of torque its far better for: a-comfort, b-fuel economy/emissions output and c-longevity of the engine etc if rpm's are lower. If you would put that gearing over 5 gears, that would massively reduce performance. So for the slow us style of driving that many gears might not be as necessary as the high speed driving we do in Europe, where a US gallon of fuel can cost up to $8,- (yes thats another thing that differs...). Also cars and car manufacturers have to meet strickt emission goals; putting in a 5 speed would mean bmw wouldnt even be allowed to produce an m3 or m5. Those are the reasons why the went from 4 to 5 to 6 and next 7 gears (automatics are already up to 10)
12-17-2017, 03:21 PM | #14 | ||
11825
Rep 15,400
Dude. Just dude. And i admit i tried to explain the F8x gen here, so the second dude was for me.
GuidoK10626.00 |
12-17-2017, 04:17 PM | #15 | |
Rep 2,138
Drives: 2011 E92 M3
The E92 M3 is engine limited to 168MPH in 5th gear at 8300RPM with 6MT and 3.85 gears (6th really cannot go faster due to resistance anyway). Same transmission, in 6th, you are theoretically at 7221RPM. Not a great deal different. For the US and Canadian folks who are limited to slow highways: at 70MPH in 6th, the 6MT above is pulling 3000RPM, or 3448 in 5th, or 4103 in 4th. Since 5th will get you to Vmax, 6th should be a better overdrive gear. Any more gears and you might as well buy an automatic or a CVT IMHO to make up for all the time wasted changing gears manually. Thankfully, BMW has not swallowed the 7 speed kool-aid yet (they may just drop M manuals since so few are sold though...). Corvette and Porsche have. But at least the Porsche GT3 manual has only 6 forward speeds!! Cheers,
12-17-2017, 04:23 PM | #16 | ||
11825
Rep 15,400
12-17-2017, 04:33 PM | #17 | |
Rep 2,138
Drives: 2011 E92 M3
Yes DCTs are faster. But so are CVTs. And CVTs are soulless.
Lups11824.50 |
12-17-2017, 04:46 PM | #18 | ||
11825
Rep 15,400
If you look closely, you can see a tiny bias towards to those who really can drive in my post. I did about 32 k miles in a manual F82 and a few more in dct versions of that generation. It's been almost two years since i sold my f82 and i still haven't bought a car to replace it. That's how bias I am to manuals (and i have a mild problem with giving up things i name, i rather walk than buy an other F8x and the next gen won't have a manual, so i guess walking is an option!) , but some mild stubbornness have been detected in my case. Edit: An e90 M3 has been looked at by me twice in the passing months so i guess I'm turning back the time in this too. It's a manual, naturally.
12-17-2017, 04:50 PM | #19 | ||
#buildnotbought
10626
Rep 4,848
Take for instance the peugeot 306 GTI-6. I dont think you ever got that on you continent, but it's basically a late 90's hot hatch with a 167hp engine and close ratio gearbox. That car is an absolute feast to drive with that close ratio gearbox. Like having a little old fashioned ralleycar, its regarded as one of the best 90's hot hatches. But again, that engine benefits from the close ratios. At 136mph it will hit the revlimiter in 6th. And for instance a clio RS will hit the revlimiter in 6 at the same speed, also pretty close ratio. Quote:
But then again, the amount of gears is not all about top speed. Its also like I wrote about emissions, engine characteristics, mileage, longevigy and comfort. Those factors combined make up what gearbox and ratio's to use. And of course weight and size. A 7 speed is considerably larger due to its construction, as it not only needs an extra gear (that goes for all gearboxes with more gears), but also an extra shift fork. That is also a reason that 7 speeds arent that common.
12-17-2017, 05:08 PM | #20 | |
Rep 2,138
Drives: 2011 E92 M3
I still think 6th gear could be a much better overdrive. And that 7 gears are not needed (unless you are driving a highway tractor).
12-17-2017, 05:13 PM | #21 | |
#buildnotbought
10626
Rep 4,848
Cause thats the physical consequence. Every extra gear gives in theory better performance. Thats why in professional motorsports every track has its own set of gearbox ratio gears. To maximize performance for the stretch of road it gives and fit the ratio's as close as possible. Automatics even get 8-10 gears in order to keep up with (or surpass) manuals in acceleration or mileage etc.
12-17-2017, 05:15 PM | #22 | |
11825
Rep 15,400
160+ mph is all I've done in an M of any generation. Six speed was still enough for that.
