      01-07-2014, 09:39 PM   #23
LSM
LSM's Avatar
Drives: 2024 Porsche 911 GTS Cab
I realize it will cost more and probably not give the same types of gains, but I am waiting for the Dinan tune. I spoke with them today, release for M6 will be "early spring" You can also then sell the tune later or the car with the tune at a premium...Fully warrantied, no issues...I like that
2024 Porsche 911 GTS Cabriolet
      01-07-2014, 09:51 PM   #24
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Originally Posted by mr-karim
lets say 635 horses at the wheels, + AMS Downpipes and Akrapovic exhaust and Gruppe M intake, should be well close to 700whp, and over 800hp crank. Manhart racing is basically same stuff (intake + exhaust + dp) + (Manhart ECU)
Originally Posted by gmd2003 View Post
Stage one with intake and DP's will not get you 650whp . The one guy who got 630whp was running extra boost over stage 1 and maxing out the safety margins of this "tuning " approach . You need full control over fueling /timing to safely do 650whp and up even with supporting mods . Just trying to keep your expectations realistic . You can make a dyno read anything you want though like ECU tuning group so ....
That run was with carbon delete and catless downpipes and rear exhaust and 2 psi more boost than stage 1 .....
So 630whp is the most your going to get on pump gas
      01-07-2014, 10:57 PM   #25
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
gmd2003
Well Dinan is not out yet, ecu tuning group would void my warranty, and BMS is the best option at the moment. I might consider Manhart later on...
630 whp is still 724.5 hp crank (considering 15% RWD drivetrain loss), not bad for now.
Any advice or some brilliant experience you would like to share Mr. Gmd2003?
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      01-07-2014, 11:42 PM   #26
AlphaAlpineM6
AlphaAlpineM6's Avatar
Drives: 2014 BMW M6 & 2012 AMG CLS63
With downpipes I realize my car has more than adequate power. Not going to tune.. too risky
2008 M3 Sedan + catless + Tune
2012 CLS63 AMG
2014 M6 Coupe + catless + KW V3
2015 Porsche GT3
, 2015 M3, all stock, 1/1 Space Grey
      01-07-2014, 11:58 PM   #27
mr-karim
mr-karim's Avatar
BMS is not a chip tune, you don't change anything in original BMW's ECU. Basically BMS is a plug in and play; Should give a better fuel economy too.
I'll review it once I install.
      01-08-2014, 01:17 AM   #28
gmd2003
gmd2003's Avatar
352
gmd2003
Just that BMS is the best option available , Manhart, Switzer all use piggybacks to get 700 crank hp ( they just overcharge for it ) . I just wanted you to have realistic expectations about results . No need to be sarcastic . Just trying to help out someone who has less technical knowledge .
      01-08-2014, 06:56 PM   #29
turbo8765
Drives: very fast
Originally Posted by mr-karim View Post
gmd2003
There was actually a MAHA dyno that indicated 19% drive train losses, making the whp numbers that much more impressive.
On the one hand that's hard to believe, but on the other hand it's hard to argue with the MAHA.
      01-08-2014, 07:06 PM   #30
EuroKar
Piggyback (plug and play) setups are scary.
Regardless how many cars are running them, being able to "manipulate" a few sensors operating range is not a safe manner to increase performance on these late model cars. There is just too much going on with these systems to be able to push your car to the max with having peace of mind that all the engine management functions can respond correctly when need be.
But they are being made and people are running them. I would wait for a proper performance engine re-mapped file from a respectable tuner.
      01-08-2014, 07:10 PM   #31
EuroKar
I just installed the GT Haus full exhaust system including catless downpipes. With just the exhaust system this M6 put down 549HP and 499FTLB to the wheels on a Mustang Dynameter.
The charcoal filters are removed now and I have a custom engine tune being made by OE Tuning which is based out of Southern California.
I will post up information on performance gains and lots of pictures in a new post within the next 2-3 weeks once its all finished and running great.
      01-08-2014, 07:18 PM   #32
mr-karim
mr-karim's Avatar
EuroKar
Did you get a CEL with catless? Will OE tuning keep your warranty?
For sure post pics and videos
      01-08-2014, 08:52 PM   #33
gmd2003
gmd2003's Avatar
352
While I agree full ECU control is best , I'm starting to think no one will crack this ECU . OE tuning has been selling the same modified development file as everyone else . If you want proof ask them to remove the speed limiter and prevent a CEL from running catless and see what they say .
      01-08-2014, 08:53 PM   #34
gmd2003
gmd2003's Avatar
352
EuroKar
Everyone gets an emissions CEL for running catless . No way around it .
      01-08-2014, 08:55 PM   #35
mr-karim
mr-karim's Avatar
Schnitzer offers to move up the limit to 310km/hr
      01-08-2014, 09:00 PM   #36
gmd2003
gmd2003's Avatar
352
That's the same speed as the European only M drivers pack option . They obviously got hold of it .
      01-09-2014, 10:04 AM   #37
EuroKar
I know that all software tuners are battling the same issue.
This vehicle is going to their main facility for testing.
That's what the hopes are for.
I already have their performance tune which turned this car into another BEAST !! Having the "Check Engine" light off would be great too.
I have no had a dyno run after their tune yet, still waiting on software to be error free.
      01-09-2014, 12:04 PM   #38
SlashM3
Drives: 09 E93 M3 interlagos
This ecu tuning group says that they offer a module to remove and add tune at anytime? So warranty shouldn't be a issue.
      01-09-2014, 01:11 PM   #39
btbossman
Drives: 2013 335xi M sport--2014 M6
Yess sir!!!!! I have never put a dp on any other car before(was about to on my 335 but said F it) but damn can you feel the differance on the m6!!!
      01-09-2014, 02:21 PM   #40
gmd2003
gmd2003's Avatar
352
It's a piggyback that tricks the TMap sensor like BMS , except I'm pretty sure they will charge you more than 400 bucks for it lol .
      01-09-2014, 03:23 PM   #41
SlashM3
Lol some where around 2400 when I spoke to jags
      06-08-2014, 05:44 PM   #42
amweigh
Drives: 2013 Frozen Black F10 M5
2012 BMW X5  [0.00]
2013 BMW M5  [0.00]
Tom C
My local ECU dealership promised me a free dyno run if I decide to go with them.
Right now I'm waiting for AMS catted downpipes, and Akrapovic exhaust to come, looking forward to install, and hopefully Dinan will make their ECU tune soon.
How did the AMS catted downpipes work out for you?
      06-08-2014, 06:30 PM   #43
mr-karim
mr-karim's Avatar
it's ok, but tbh all you need is a BMS tune (to get over 600whp) and an exhaust (akrapovic, meisterschaft, eisenmann) just for the sound.
      06-08-2014, 08:04 PM   #44
amweigh
2012 BMW X5  [0.00]
2013 BMW M5  [0.00]
I have the Dinan Exhaust but it is still pretty mild. Have you gotten any error codes from the downpipes?
Tags
bmw, chip tuning, dyno, ecutuninggroup, racing
