      11-23-2013, 04:14 PM   #1
templarklimek
templarklimek
Drives: 15' X6M, 12' R8 V10,
19 inch vs. 20 inch rims unsprung weight
Gents,
Just found out the rims on my inbound M6 are 19's. Is it true that the 19's with tires weigh less then 20's with tires and thus reduce unsprung weight?
I like the look of the 20's but weight is an enemy of this car already. Thanks for your advice.
      11-23-2013, 10:53 PM   #2
RiverRunner
RiverRunner's Avatar
Drives: 2014 M6 Gran Coupe
Why are you worried about the weight?
2015 740i Sapphire Blk/Blk
2018 Tahoe RST 6.2
2019 Porsche 911 Turbo 991.2
      11-24-2013, 08:39 AM   #3
templarklimek
templarklimek
unsprung weight affects the "off the line" performance. Think of it like trying to sprint in a pair of boots or running shoes.
      11-24-2013, 01:05 PM   #4
jeff4598
Drives: 2019 M2C HS, DCT, much Dinan
It hugely effects handling feel, much more of an issue than acceleration as acceleration is somewhat traction limited any way and you floor it only now and then from a standstill but you constantly go around curves and corners!
      11-24-2013, 01:20 PM   #5
templarklimek
templarklimek
so what is the better choice for performance 19 or 20? TY
      11-24-2013, 02:16 PM   #6
noushy
///M Fan
noushy's Avatar
1657
Drives: M8 Comp, X5M Comp, iX M60
Aftermarket HRE wheels are even lighter than factory 19 and 20 inch forged wheels. Can also do ceramic brakes and titanium bolts and lugs to drop weight even more. The Carbon Ceramic Brakes (ccb) drop 12 pounds per corner of unsprung weight, bolts 1 pound and wheels 2-5 pounds.
Peace
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      11-24-2013, 07:04 PM   #7
templarklimek
templarklimek
Thank you Noushy, I've been reading about your M6. Simply uber awesome. Sadly, this was the only manual tranny M6 in the states and no carbon brakes. Is swapping the rotor/pads a possible future aftermarket option. I like the weight savings.
      11-25-2013, 06:39 AM   #8
bjayfan
Drives: 2014 F13 M6
If your car has 20" wheels you can add the CC brakes through M-Performance parts.
      11-27-2013, 08:13 PM   #9
RiverRunner
Gents,
This was what I was referring to. If you've noticed, acceleration will not be effected by unsprung weight in the M6, traction is the problem. As for weight, you'll need to remove more than the weight of a 20" vs. 19" wheel to make a difference in acceleration. You want to drag race the car, put some slicks or Mickey Thompson drag tires on 16" wheels, and handling will go to heck, but you'll hook up. Taller sidewalls are better for drag racing, off the line traction.
2018 Tahoe RST 6.2
      12-04-2013, 02:47 PM   #10
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
Even if they weigh the same, the smaller wheel will have an advantage in rotational inertia.
      12-05-2013, 12:51 AM   #11
RiverRunner
Not since the tire diameter is the same.
2018 Tahoe RST 6.2
      12-05-2013, 11:22 AM   #12
TheSt|G
TheSt|G's Avatar
You are assuming the radial weight distribution is equal, it isn't.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      12-06-2013, 01:44 AM   #13
RiverRunner
The tire and aluminum rim weights are not much different, and will not impede the performance of this car's acceleration. If you've owned or driven one, you'd know that traction is the issue not rotational inertia or any related energy spent creating such inertia.
2018 Tahoe RST 6.2
      12-06-2013, 04:21 AM   #14
DreamerM6
Drives: BMW F13 M6
Peace
Noushy
Please tell me where to buy it! Sounds like a good plan!
      12-06-2013, 04:24 AM   #15
DreamerM6
Drives: BMW F13 M6
Ive put some Toyo R888 315/30/20 tyres on my M6 and traction is no longer a problem! improved 0-100 time by .05 sec on my M6! 4.2 to 3.7! Try it trust me youll be happy!
      12-06-2013, 08:30 AM   #16
TheSt|G
TheSt|G's Avatar
I have driven one, not a car for me.
Straight line acceleration is just one performance metric impacted by rotational inertia.
      12-06-2013, 02:16 PM   #17
noushy
///M Fan
noushy's Avatar
1657
Peace
Noushy
The ti bolts can be had from Tikore in Florida. CCB upgrade package available through the dealer. HRE and most high end wheels can be had by several vendors here on the forum
