04-05-2020, 09:18 PM | #1 |
Rep 287
Soft Close Doors...Wont Soft Close?
2016 640i Coupe'
About 2 weeks ago, the drivers side wont soft close. so i have to close the door a little harder. when i close the door i hear the mechanism trying to do something and 2 seconds later try again anyone ever experience this? |
04-06-2020, 07:51 AM | #2 |
Rep 198
It is your soft close actuator they are made out of cheep plastic and they go bad frequently , I chance my 3 times twice drivers door ones passenger very poorly made shame on bmw 100k car cost of repair with labor $1160 each !!!!
04-06-2020, 11:28 AM | #3 | |
Rep 7,529
In regards to the noise you hear...that is the soft-close feature double checking that the door is actually closed. As you can see in the info below...when the door is MANUALLY closed (or slammed)...effectively bypassing the soft close feature...the system is designed to check that the door is closed:
04-06-2020, 01:21 PM | #4 | |
Rep 287
@ 1200 a repair 3 times would have made me pissed. now i know what the issue is i will decide if this is something i will tackle or pay someone to do. i may wait a while to see if a better replacement comes along thanks guys! |
04-06-2020, 07:39 PM | #6 | |
Rep 7,529
Going back to the BMW TIS website to get more info and another image...you can see in the pic below how the soft close drive & door lock are connected.
05-06-2021, 09:29 AM | #7 |
Rep 287
super bump.
so 2 weeks ago the car makes a grinding noise. when the soft close door does the extra attempt to close. i quick youtube search shows the soft close unit brakes. and i just got quoted 525 for a replacement part that has to be coded to the car. once its bought there is no cancelling or returning the part. also seems to be a bmw only part as there is no other vendor supplier. is there a way i can disable or cut power to the driver door mechanism until i do the DIY? there is a DIY on youtube to do this job btw. |
05-06-2021, 01:15 PM | #8 |
Rep 738
My question is, is it worth $1000 for the soft close function as long as the door locks and unlocks like a normal door? It wouldn't be for me.
05-06-2021, 02:06 PM | #9 |
Rep 287
its not honestly.
I lived a good year with out it back when i made this post. but this loud gear grinding is annoying and embarrassing. if I can cut power to the mechanism ill do that. maybe just unplug it when i have a day to do work on the car |
05-07-2021, 03:08 PM | #11 |
Rep 7,529
My interpretation from reading the BMW tech info...soft close is a stand alone feature. It reads as if you could unplug the electrical connection (essentially cutting power)...and just close the doors manually. See/read the info below to see if you come away with the same thinking. The text highlighted in yellow was NOT done so for this thread...it was highlighted in regards to a question asked in a thread long ago...but the pic/info was in my “stash”...so it is being reused here.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-08-2021 at 10:30 AM.. |
01-20-2024, 03:29 PM | #13 |
Rep 284
I'm not sure if I have an issue with the power door close or just the cold. It has been very cold here in the Boston area the last few days, Wind Chill of zero this morning, so maybe it is just frozen. My car was not locked and the door opened every morning, but would not close, just bounced back open. I have used a hair dryer on the handle. while in the open position the last 4 mornings, and again this afternnon. After 4-5 minutes of hot air the power closed door kicks in and pulls the door shut. I am assuming some mechanism within the handle is freezing up or is the power close somehow causing the problem?
01-20-2024, 04:22 PM | #14 |
Rep 738
I said years ago that in this thread that I wouldn't pay ~$1000 to fix it if it stopped working. Well, this summer my drivers soft close function stopped working. I think what broke it was the seat belt buckle was in the way and stopped the door from fully closing. Mine makes a little sound after I close the door but nothing that I would call "grinding". I liked the feature but it's something I can definitely live without.
01-20-2024, 04:49 PM | #15 |
Rep 284
So if I understand correctly the soft close feature failing has no effect on the door continuing to operate correctly? The problem I am having when closing the door is nothing engages.
01-20-2024, 07:44 PM | #16 | |
Rep 7,529
If you don’t have a garage where you can get temps above freezing…look for a public underground parking garage where temps are above freezing and take care of some business or do lunch/dinner…which can give the car a long enough time to thaw with temps above freezing. If frozen components are the culprit…letting the car set for some time in higher temps should fix the problem.
01-21-2024, 09:25 AM | #17 |
Rep 284
Thanks Qsilver7. No freezing rain, just snow flurries. This morning when I touched the door handle to open the car I accidentally locked it. Which tells me the locking mechanism isn’t frozen. However, I cannot unlock or open the door. Getting the hair dryer out - again!
UPDATE - Less than 10 seconds with the hair dryer on the open part of the handle and the lock popped open! Last edited by Alpine650; 01-21-2024 at 11:19 AM.. |
01-25-2024, 09:36 PM | #19 |
Chieftain
52
Rep 274
Drives: E90 N54 335i
What fuse can we pull to temporarily disable soft close?
01-25-2024, 10:26 PM | #20 |
Rep 7,529
Each soft close drive has its own fuse…so which door do you want to pull?
It would probably be better to pull the electrical connector for the soft close drive in case something else is also powered by the fuse that powers the soft close drive. F110 F143 F144 F149
