03-23-2016, 10:04 AM | #1 |
Rep 737
Dinan Advice - Do I pull the Trigger
Big Brian, M6 Coupe, MrSugerskulls and all on the Forum
Victoria BMW is Now a Licensed Dinan Dealer ... so I assume no warrant issues As you know as for perf mods I did the SS Catless Down Pipes, Akra Full Evo with CF tips, and custom 21s with 325 on rear Now ... I only Get CEL on occasionally and the drivability is amazing! Princess only has 4000 km and been parked since Sept 2015 due to rain and cold weather in Victoria BC Canada Advice ... a) Leave as is and enjoy b) Dinan Stage 1 c) Dinan Stage 2 effects on reliability and Drivability? Will I be happy? Concerns? Advice Thanks Guys!
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV Past Cars: 2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban |
03-23-2016, 01:27 PM | #3 |
Rep 620
I know that having a warranty is very attractive but I'm not a fan of Dinan tunes. I had a stage 3 tune in a 335i that couldn't hold a candle to a pro-tuned Cobb setup for half the cost. The Dinan ran rich and was laggy too.
03-23-2016, 05:43 PM | #4 | |
Rep 737
They had the SS Catless Down Pipes in stock for another customer and they had installed them and within 1000 km he traded the car from a 2015 to 2016 M5 ... so they pulled the parts out and stored them till my Car came in as he didn't like the CEL issue on the 2015 with the SS Catless ... the Dealer installed them at the cost of labor to do so and said they will back it ... just as they will when they finally get licensed as a Dinan Dealership ... That was June 2015 as when I finally took Delivery of my 2016 M6 Cab I have done many car deals and provided many referrals for this Dealer Group (German Auto Import Network ... they Own Three Point Motors, Victoria BMW, Audi of Victoria, Porsche Center Victoria, VW of Victoria, Subaru of Victoria, Fiat and Alpha of Victoria and the New Vancouver Island Motorsport Center) .. plus they and they staff are Dental Patients of Mine as well See if the Warranty issue will be backed should an issue arise
Current Garage:
03-23-2016, 05:45 PM | #5 | |
Rep 737
They suggested with my set up a Stage I will put down 680 hp and 644 ft lb Stage II will do 693 Hp and 651 ft lb Big Brian? M6Coup?
Current Garage:
03-23-2016, 06:08 PM | #6 | |
Rep 3,127
Drivability wise you wont be disappointed although I am the vendor so you can take my recommendation with a grain of salt and just wait for others to chime in. |
03-23-2016, 07:29 PM | #7 | |
Rep 737
Thank-you! I will see what others feel, but most likely will do Stage I then! Much Appreciated!
Current Garage:
03-23-2016, 08:02 PM | #8 | |
Rep 620
The power gains look pretty good and the warranty should give you some peace of mind. |
03-24-2016, 08:28 AM | #9 | |
Rep 737
Thanks! I will probably do it after the first 1000 km the car is out .. or the first yearly maintenance and oil change
Current Garage:
03-24-2016, 10:49 PM | #10 | |
Rep 417
I have experienced drivetrain malfunctions, but they are few and far between. Was installed in July 2015 and I have had just 1 random malfunction. (Just don't let anyone unplug the piggyback ECU or it will get damaged) Any issues and Dinan is all over it, well worth the warranty. Not sure what extra HP you will get with DPs since Dinan only tests with OEM catted DPs.
03-24-2016, 11:33 PM | #11 | |
Rep 737
That is good to know as this will be my summer daily driver topless! (if it would ever stop raining)
Current Garage:
03-25-2016, 12:00 AM | #12 | |
Rep 170
Are you a GP or specialist? |
03-25-2016, 12:11 AM | #13 | |
Rep 737
You?
Current Garage:
03-25-2016, 12:30 AM | #15 |
Rep 6,067
Well I know I am in minority here but since you asked me to say something let me take advantage and share my opinion with you .
As an Electrical Design Engineer with over 20 years of design experience I believe when a team of expert engineers design an amazing car, they think about every single component and consider every single specification to build a car on a purpose. when I design a hardware, I usually consider some overhead (to satisfy the worst case scenario) to make sure the system is robust enough to maintain unwanted events but there are many things you need to consider before you go forward. Back to our cars, I believe the current S63tu has more capability than 600 HP but it is not just engine. You need to pay attention to the other components including DCT, Differential, Brakes, Suspensions and etc. For example the DCT on our cars is manufactured by GETRAG as 7DCI700 rated to 700 NM (516 lb-ft). Germans are so conservative so basically 20% underrated spec is normal; therefore you can rely on 600 lb-ft if you want to tune your car. I have no idea about the spec of M Active differential, rear axles (as the other parts of drivetrain) or fully aluminum suspension. If you search over M5post, you can see many people have weird issues including broken axle, slippery clutch, transmission issue or malfunction drivetrain error message and you will be surprised to understand the majority of those cars are tuned! Here is one example: http://f10.m5post.com/forums/showthread.php?t=1075579 The thread was started with polling and 168 people participated. over 126 stock car, 100 owners did not experience any malfunction error while over 42 tuned car, 30 of them had drivetrain problem... You also might be interested to read some threads and get some ideas from people who already experienced them before you pull the trigger. Here you can find some of them: http://f10.m5post.com/forums/forumdisplay.php?f=438 So after that long rant If you still really want to tune your car (I would not do that but it's just me) the wise decision is to rely on someone who takes the responsibility of those issues in case something goes wrong; with this I would say stage 1 Dinan make sense for you due to Dinan's warranty ... Stage 2 is too much money with minimal benefit (1-2% ?) which is not significant... Anyway, Goodluck with your decision and hope you enjoy your ride in my second country
03-25-2016, 01:10 AM | #16 | |
Rep 737
Many good and well thought out relavent points! Yeah, reliability and daily drivability are key factors to consider ... Bolt on parts have always been good in my experience ... Other than hyper tech tuning on our 2002 chev suburban, all other cars got bolt on perf parts or aesthetic additions We have never had an issue with any car re reliability or safety to date ... And yes I have read about the drive train malfunctions and broken axles on many threads ... Thus the question from those much wiser and more experienced in such matters ... I will likely track the car but as a cab never crazy ... Will get a alpha Romeo C4 for that or porsche Cayman ... So enormous steroid car power not a necessity ... Sorry BigBrian ... I am amazed at all you have done with your car and can only look and ( turning my little A to a DD ) ... Nice picture of you by the way in your last threat, makes me think the M6 coup maybe to tiny for a man of your stature With a busy lifestyle, kids under 9 years, crazy busy practice I don't want down time with my toys ... I had a three piece 22 inch custom rim that started to leak after a pot hole and that sucked ... Down time ... Swapping rims etc etc then getting the warranty repair Thus why I ask what others think and have experienced ... Cost is not the issue ... Reliability is key and warranty should the change cause a problem!!! Many good points as I would expect from you M6-Coup thank you! BigBrian ... What modes did you need to utilize the Goliath power you have harnessed so as not to twist your amazing ride like a towel being rung out? Much respect to all ... I intent to keep my cabs for at least 7 years and put 5000 km per year on them ... Other cars swap out every 2 to 4 Any other advice and experience from others? Thanks
Current Garage:
03-25-2016, 11:11 AM | #17 | |
Rep 737
There seems to be some issues ... Not sure if tune related or (loonie tunes) anvil right foot syndrome ... And higher Hp and torque numbers facilitating the issues ??? Last edited by 2007 to 2016 M6 Cab; 03-25-2016 at 11:44 AM.. |
03-25-2016, 11:43 AM | #18 |
Rep 737
03-25-2016, 12:43 PM | #19 | |
Rep 3,127
03-25-2016, 03:53 PM | #20 |
Rep 1,299
Drives: 2015 BMW i8
My only issue with the Dinan tune is that your spending a large amount of money for you car to still be slower than another M6 with a $500 tune.
H&R Springs 21" ADV.1 ADVNL2 MV2 CS Wheels Coming Soon: 2016 BMW M4 GTS De-Winged and Bagged on 22s |
03-29-2016, 10:13 PM | #21 |
Rep 737
Thanks ... good to know!
Current Garage:
06-24-2016, 01:26 AM | #22 |
Rep 737
Ok ... Dinan Stage II unit installed today ... Dinan CF Air-intake goes in soon .. they didn't have the template to cut the front end under the hood to accomodate the parts ...
The drive home today ... No CEL ... and in second gear a little tap and the traction control light kicks in and I feel a slight hop in the rear end as I get on the highway on ramp and start accelerating ... Seems to be a bit more eager to spin the rear tires .. definatley feel a bit more of a punch as we accelerate! I will kepp you posted as the intakes go in ... and then get the pics uploaded of the exhust set-up and the Dinan ... Talk soon ... and thanks for all who had wise words to help with this decision! Cheers!!
Current Garage:
