08-27-2023, 07:51 AM | #1 |
Rep 102
50k mile service and tire wear question
Well, my wife talked me into keeping my 2014 650ixdrive convert, says it a great date night car, but that also means i have to perform the 50k mile service which i think is a big one. Aside from the obvious, Oil change, Spark plugs and tire rotation, should i do anything else? Trans fluid change, coolant, etc?
Also, im getting odd tire wear on the inside of the two front tires. Basically its wearing on the inside part of the tire edge much faster than the rest of the tire and that seems to be a trend given thats why i had to replace the two from tires about 20k miles ago. They aligned it when they replaced the tires, done by the dealership, and its been aligned several time prior to me owning it according to car fax. Is that just normal for these xdrive cars, or do i have another issue besides alignment i need to look into? thx Last edited by cdog2964; 08-27-2023 at 07:53 AM.. Reason: couldnt upload video |
08-27-2023, 12:29 PM | #2 |
Rep 7,548
There should be a maintenance/service booklet in your owners manual binder, too…that can give you an idea of what services to perform based on mileage.
08-27-2023, 03:12 PM | #3 | |
Rep 2,919
08-27-2023, 07:03 PM | #4 |
Rep 102
Yes, i understand the normal maintenance schedule, but my question is since the car has been sitting so long with not a lot of miles put on it, should i consider accelerating the fluid changes and not wait another couple of years until i have the correct amount of miles on it to do the scheduled maintenance?
08-27-2023, 09:07 PM | #5 |
Rep 2,919
Your question didn't say anything about the car "sitting so long." And we don't know what that means even now. I have a one year newer car with similar miles, and at no point would I say it has been "sitting." At or around 50k I did plugs, tranny fluid, front and rear differential fluids and transfer case fluid. But that's just me - I didn't do it because of sitting or any other reason. 50k is just a nice round number, so I celebrated it. I still have not changed the coolant. Maybe someday I will.
08-28-2023, 03:35 PM | #6 | ||
Rep 7,548
I would throw in one more fluid change that wasn't mentioned...and that would be to change your brake fluid. Brake fluid is hygroscopic (absorbs moisture) which degrades the brake fluid's effectiveness. It should be changed on a 2-3 year interval.
08-28-2023, 05:06 PM | #7 | |
Rep 102
Thx again |
