02-07-2017, 09:12 AM | #1 |
Rep 365
what oil to in my '13 650i n63tu 36k
My prepaid maintenance is about to expire so I'm wondering if from now on should I look for a better grade of oil and have the dealership use that for my next oil change or stick to what they use out of their bulk tank? I will be doing my oil changes every 6mo. or 7500mi and put my car away in a heated storage for the winter if that helps thx ahead
02-07-2017, 10:50 AM | #2 |
Rep 738
So here is a quote from the 2013 "Service & Warranty Information" booklet.
"BMW recommends that you check your engine oil level whenever you add fuel to your vehicle. If you need to add oil between oil changes and BMW High Performance Synthetic Oil is unavailable, you may top up the oil level with one of the following approved synthetic oils. For information on checking your engine oil level, refer to your vehicle’s Owner’s Manual. The synthetic oils listed below meet BMW’s Long-life rating LL-01: . Castrol Syntec European Formula SAE 0W-30 . Mobil 1 SAE 0W-40 . Pennzoil Platinum European Formula Ultra SAE 5W-30 . Valvoline SynPower SAE 5W-30" I will be using Mobil 1 SAE 0W-40 after the last warranty oil change. |
02-13-2017, 04:31 PM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Liqui Moly or Motul 5w-40
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-13-2017, 04:36 PM | #5 |
Rep 365
on my repair order the dealer says they put 5w30 under warranty so 5w40 will be safe in hot climate and some hard driving every once in a while? thanx for your input!
02-13-2017, 05:56 PM | #6 |
IG @bmwF9xG80
3813
Rep 7,593
40 is thicker and for hard-driving is what most guys with tune as well are running
