      03-06-2017, 08:09 AM   #45
darms
darms's Avatar
56
full guide will be appreciated mate (hope its not too much a of a pain)
F30 LCI M Sport Shadow Edition Mineral Grey
      03-06-2017, 08:09 AM   #46
325_bucks
Drives: F90 M5 Competition
Originally Posted by Apr1962 View Post
The 640D tips do slip off, but to retrofit the BMW square tips you need to cut quite a few inches off of the exhaust itself. You have to cut them right back to leave a stub.
Is there an easy way to measure where it needs to be cut?
      03-07-2017, 08:08 AM   #47
Apr1962
Drives: 640D
I left enough on the silencer to clamp the tailpipe on from memory, didn't want them to stick out. Cut off with an angle grinder.
      03-07-2017, 08:10 AM   #48
325_bucks
Yep, I've received the fitting instructions from BMW. The amount you need to leave is 55mm, which leaves it flush with the trim. I've purchased a chain cutter so will see how I get on. I won't be able to do this until the weekend due to light levels after work.
      03-08-2017, 05:41 PM   #49
325_bucks
Managed to try to do this after work today. Was pretty easy except I made a hash of cutting one of the pipes but got there in the end. Need to go back to deburr with an angle grinder at the weekend but doesn't affect the actual fitment. It seems one silencer hangs a few mm lower than the other but I've also seen this on other cars. I've got a picky eye but don't think it's noticeable really. Unfortunately it was dark before I got round to taking a picture so will take a new one tomorrow
darms55.50
      03-09-2017, 01:21 AM   #50
darms
darms's Avatar
56
Well done for doing it on a school night
Looking good look forward to seeing it in the daylight and see how low it actually sits
      03-09-2017, 02:34 AM   #51
325_bucks
Here's a picture from this morning
darms55.50
      03-09-2017, 02:49 AM   #52
darms
darms's Avatar
56
Very smart..... job well done
      03-09-2017, 03:10 AM   #53
325_bucks
if I get some time after work again I'm going to grind down the left tip where I cut it off a little bit, I think I could adjust the height of the tailpipe a bit by smoothing it out. The right tip was cut cleanly. If I can't then it's not the end of the world, it is barely noticeable unless you're looking for it, its about 2-3mm lower. Like I said however I've not seen a single picture of these retrofits where they are exactly the same on both sides though.
      03-09-2017, 03:31 AM   #54
a.s.uk
Drives: F13 640d M sport
Looks cool mate
Can't notice the lower tip
How easy did the black lower diffuser come off the bumper...
I wanna carbon wrap mine... The wife hates the look of it plain in grey....
Cherrs
      03-09-2017, 03:33 AM   #55
325_bucks
Originally Posted by a.s.uk View Post
Looks cool mate
Cherrs
Really easy, it's the one part I couldn't find instructions for but just release the 2 expansion rivets on the left and right and then it just pulls off, start at the edge using the area you remove the rivet from and work along. Once you get enough off, it's easy. Just pull with shallow angle, i.e. don't bend it away from the car too much as you pull, although it's quite tough and takes a lot to deform it
darms55.50
      03-09-2017, 07:21 AM   #56
325_bucks
Well, I couldn't wait, I'm impatient, so got the angle grinder out at lunchtime and tried to see what I could do. I've managed to get things pretty much spot on, there's probably about 1-1.5mm difference now, or less.
Here's a crappy picture, I can't seem to find the best light to photograph this but I'll keep trying!
      03-09-2017, 07:37 AM   #57
MSUGOGRN
Drives: 2021 Black X3MC
Looks great!
      03-09-2017, 07:38 AM   #58
325_bucks
I actually think im going to leave them chrome for now. If nothing else, I'll have to take them off to send them to coat so will be without tailpipes. What I might do is order the aftermarket black chrome versions that seem to be a direct replacement and see how they look, but with the blue car, I think they actually look good in chrome
      03-10-2017, 01:09 PM   #59
Mark333032
Mark333032's Avatar
63
Nice mod. I'll look into this one myself
      01-29-2024, 05:21 AM   #60
RoderickW
Drives: E38 750i , F06 640D
Originally Posted by PIT F06 View Post
Hi,
should work fine !
It fits to M-Sports package .. not M-Performance muffler ...
You need the diffusor with part number 51128050378 .. same as shown in the link.
Btw., I have the square tips on my 640d .. but no M-Sports package ..
Hi, I´m new here, and also looking to change my exhaust tips to the square ones.
For the most part I can only find this option for the Bumpers which have the reflectors a bit below the tail lights. The bronze F06 in this thread has the same bumper type as I do, with the reflectors a bit more below on the bumpers.
Does the discribed diffusor and square tipsalso fit on that type of bumper?
