11-29-2016, 10:32 AM | #1 |
Rep 12
Best Oil for M6
I am sure there are posts on here but I couldn't find anything answering what the best is.
I just purchased a 2014 M6 GC Competition Package and I want to purchase a couple quarts of oil to keep in the trunk as I did with my M3. I am seeing 4 different options. The 0w30, 0w40, 5w30 and 5w40. Now which is the best to go with and brand? I live in warm Miami so don't need anything specific for cold weather. thank you. |
11-29-2016, 12:49 PM | #2 |
Rep 78
I use 5w30 and a well known make (varies depending on what specials are running). I do however change it every 3-4K miles and not the pathetic long intervals BMW suggest!!
11-29-2016, 02:14 PM | #3 |
Rep 436
That's calling the kettle black, BMW engineers are crap but you buy specials and change every 3-4K .Why would you want to change your oil at that small mileage .
11-30-2016, 02:27 PM | #5 |
Rep 422
I am using two oils at my BMWs. At F13 M6 i am using Motul 300W 5W40 with maximum 8k km change intervall (no track drive). On my wife m235i i use Shell Helix Ultra 5W40 with maximum 10k km change. On my M2 at the first oil change we have put BMW M Performance 0V40 oil (aka Shell Helix), but the next oil change, i will change it to Shell 5W40 or Motul 300W 5W40 with 8K km intervall.
12-06-2016, 04:24 AM | #7 |
Super Member
129
Rep 344
I change my oil every 3-4K miles as well, I drive my M6 hard every now and then and by 3k miles the oil is black. I just recently switched over from the original twin turbo BMW oil to 5w-40 Liquid Molly. So far I like how it doesn't burn as fast as the BMW Oil. I would always have to add a qt when I would get close to 3k. I was told this is normal, I have yet had this issue while running liquid Molly.
07-13-2017, 01:32 PM | #8 |
Theo
Rep 16
Hi guys,
here is what I use on my M6 F13 and believe it or not it does not burn oil anymore.. Liqui Moly 2249 Leichtlauf Special LL 5W-30 Motor Oil.. Also I change my oil every 4-5k miles just to be in the safe side(turbo maintenance).. |
07-15-2017, 06:35 AM | #9 |
Rep 3,071
I am burning a quart every 700 miles on BMW Twin Turbo Oil. I see some of you state that the Liquid Moly does not burn. What was your oil burning consumption before?
07-21-2017, 09:07 AM | #12 |
Super Member
129
Rep 344
I would get the add a qt after 2500-3k miles when using the original. Now with the Liquid Molly 5w-40 I have yet to receive that message and I've been using it for over 7months now.
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust |
07-21-2017, 07:07 PM | #13 |
Rep 3,071
I think 5w-40 is too thick. Could damage engine
07-26-2017, 02:19 PM | #15 |
Rep 126
In the UK, BMW recommend 0W-30 for the M6. I'm changing oil at about 8 to 9000 mile intervals, and so far have never needed to top it up at all. The electronic oil gauge indicated still at maximum just prior to the last oil change. That's if the gauge is to be believed! I've a BMW Service Pack on the car, but the last £00 invoice doesn't state what make of oil my BMW garage put in...
07-29-2017, 03:23 PM | #19 |
Rep 436
02-06-2021, 04:53 PM | #20 |
Rep 9
I change my oil once/year whether it needs it or not.
Cheapest thing you can do for your car. Coming from the Motorcycle World, you will find that this is the single most discussed, and disagreed upon topic. I also believe that if you rarely if ever encounter temps at or below freezing, 0w is not necessary, and 5w is fine. And on the top end, if you don't see 100 deg F often or at all, 30w works. Everything else is personal preference. |
02-06-2021, 05:26 PM | #21 | |
Rep 184
As for the original post I use the oem oil and i change my oil every 2.5k-3k miles. I drive rather aggressive and have stage 2 tune fyi. |
