E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Upgrades to support tune
Reply
      04-04-2014, 08:59 AM   #1
mister wiggles
Drives: F10
Having a tune is really fun. The car feels alive and the feeling in my gut during hard acceleration is like the entire shaft and realizing there's room for the balls too. I've recently blown my charge pipe and planning on upgrading it with an aluminum fixture.
As higher boost levels are introduced into the turbo system, what are some of the other components in the that are known to fail? I don't plan on going past Stage 1 aggressive on Cobb AP 2 - likely to stay Stage 1 sport for DD. If I upgrade the charge pipe (no BOV or upgraded DV), can I boost around relatively carefree of anything else exploding in my engine?
I really hate limping around like a prius with 4 fatties crammed in the cabin on a hot summer's day going uphill.
      04-04-2014, 09:34 AM   #2
Jklad
Jklad's Avatar
Drives: 2007 335i Coupe
Upgrade your dvs along w the charge pipe, that would be next to go.
Also get a fmic, you won't regret it.
2007 E92 335i MT
      04-04-2014, 09:36 AM   #3
N0Chill 335i
N0Chill 335i's Avatar
Drives: 13' F30 335i M Sport AW
Catless Downpipes.
      04-04-2014, 09:39 AM   #4
Eat.Sleep.Race
Out Boosting...
Drives: F30 335i M-Sport
charge pipe, and blow off valve first, then downpipes. Then FMIC.
And btw good jokes lol!
Alpine White M-Sport F30
      04-04-2014, 09:46 AM   #5
KMEninety335
KMEninety335's Avatar
Drives: E90 Monaco Blue 335i xdrive
Why not Stage 1 Aggressive for DD? There's no difference besides WOT. Charge pipe and DVs or BOV would probably be next. Then downpipes for more power or FMIC for more constant power. Your call.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
      04-04-2014, 10:33 AM   #6
mister wiggles
Drives: F10
The stock dv's should hold up fine. The only reason I see to upgrade is for better boost pressure. As long as things to break, I don't see a reason to replace.
Are the downpipes known to fail? I understand this as a "more power" mod. I like the stock design of the DV back into the intake. If the car was pushing more boost maybe a BOV would be desirable. Not a fan of the car reminding me I've shifted gears each time by playing a whooshing note.
Aggressive mode makes me anxious to race anything that pulls up besides me. It's like running on a treadmill at a 7.5 pace and someone gets on next to you and starts going running at 8.2 pace...9.0 it is bitch. I also find fuel economy is marginally better running drive/sport maps.
      04-04-2014, 10:36 AM   #7
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
I would not recommend downpipes to someone who is staying conservative with their vehicle plus he already said he is not going past stage 1. Stage 2 would require downpipes.
Change the charge pipe and get an FMIC. The car will run a lot happier with an FMIC and you can run Stage 1 + FMIC map (arguably more powerful then stage 2 alone with no FMIC).
      04-04-2014, 10:56 AM   #8
Jklad
Jklad's Avatar
+1.
Also, on 'drive' map your bumping boost from 8psi max to 14-16 I believe. The stock dv's weren't meant to handle that much boost, if you take a look at them when apart you'd wonder how they even hold stock boost levels.
2007 E92 335i MT
      04-04-2014, 01:03 PM   #9
KMEninety335
+1.
Yeah, I just got the Roc-Euro Hyperboost DVs and called it a day. I don't like BOV and wanted to keep it conservative as well. Forge DVs are good as well. I think it is more a precautionary mod than anything else but they are known to fail with more boost.
      04-04-2014, 02:18 PM   #10
mister wiggles
Drives: F10
Q1: Is there any literature that states boost ranges for different maps?
ie
Stock 0-8psi
Cobb Stage 1 Drive 0-12psi
Cobb Stage 1 Sport...
Cobb Stage 1 Aggressive...
Cobb Stage 2 + FMIC...
etc...
I'm sure one for JB4 maps would be useful too - just not to me because I chose the blue pill instead of the red.
Q2: Does anyone know if the Dinan tunes changes out any other factory parts or is it purely a tune?
      04-04-2014, 02:41 PM   #11
Jklad
Jklad's Avatar
No lit that I'm aware of.
I made a mistake above, meant to say that stage 1+ sport was makin 16psi, stage 1+ drive making up to 13.
2007 E92 335i MT
      04-04-2014, 02:42 PM   #12
_shim
Drives: an e90
ie
Stock 0-8psi
etc...
Go on Cobb's website. Hit the maps tab.
Select your car/ecu and the requirements are there.
      04-04-2014, 03:10 PM   #13
mister wiggles
Drives: F10
Believe it or not, I checked the most obvious place to see if my question could be answered. The Cobb site tells you the power increase for each map identified by "nice bump, healthy increase, maximum power" - nothing specific.
That's like asking how big are the sandwiches and getting a response "about this big, thiiiiis big, and thaaaaaaaaaaaaaaaaaaaaaat big."
6in, 8in, 12in i can relate.
I guess I could call the kind folks at Cobb and ask about their sandwiches.
      04-04-2014, 06:14 PM   #14
V8bait
Drives: e92 335i 6mt
I just died.
FMIC and DCI will provide safety and make things easier on the engine and turbos at virtually all times.
Downpipes will make things easier on the engine and turbos, but only if you do not increase power output. If you increase power output with downpipes, the engine will be stressed similar to before, but the turbos will be working harder. Also, emissions are shady.
Careful with the balls.
      04-04-2014, 06:28 PM   #15
Jklad
Jklad's Avatar
I just died.
And queue the DCI trolling in 3...2...1...
2007 E92 335i MT
      04-07-2014, 04:39 PM   #16
mister wiggles
Drives: F10
Looks like everyone that upgrades their chargepipes attaches a whistle to them. Might have to get a new one. :/
      04-07-2014, 07:41 PM   #17
Jklad
Jklad's Avatar
Lmao!!!
It's strange....This forum really let me down this time...At even the slightest mention of dci's, all hell usually breaks loose and the trolls come out of their dens....
2007 E92 335i MT
      04-07-2014, 07:46 PM   #18
georgelb
nsomneeak
georgelb's Avatar
Drives: E92 RB 335i
2007 335i  [8.00]
The best upgrade for a tuned 335i is a wallet upgrade.
RB Turbos w/ N20 TMAP Sensor | 93 Octane Protune by Cobb Plano | xHP Stage 3 | BMS DCI | STETT CP | Forge DVs | RB PCV | Helix FMIC | CP-E Catted DPs | Walbro 450 | Bilstein B12 | M3 Control Arms | Defiv Lockdown Kit | BBS CH | Michelin A/S 3+
Hixson BMW of Monroe, LA - Shady Dealer |
      04-07-2014, 11:00 PM   #19
V8bait
Lmao!!!
Did I miss something? I usually only post on this particular forum when I'm drinking/drunk...
Reply
Tags
charge pipe, cobb, reliability, tune
e90post
