      02-21-2024, 11:12 AM   #1
KnockTsuKow
KnockTsuKow's Avatar
56
Drives: f80
Will 20's m3 wheels fit on my m6?
Staggered 20” wide rims for M3 and M4 (OEM). May fit other BMW models and fitment is 5X120 (rims only). Offset= Front 20X9, ET 29 and Rear 20X10, ET 40. Wheels have no cracks, bents and original center caps included.
Will this size fit on my 2009 M6?
      02-21-2024, 03:34 PM   #2
Qsilver7
Qsilver7's Avatar
What wheels do you have and what are their specs? Compare your wheel specs to the ones given above. If they are the same specs, then they should fit. If the specs are slightly different, then compare your wheel/tire specs to these wheels (and the correct size tire for that 20" wheel) and see what the differences are at this site...if there are any differences...are they tolerable: www.willtheyfit.com
They gave you:
  • wheel bolt pattern: 5x120mm
  • front wheel specs: 20"x9" w/29mm offset
  • rear wheel specs: 20"x10" w/40mm offset
