01-28-2024, 12:56 PM | #3 |
Rep 7,486
Have you re-opened and closed the hood solidly to see if it goes away? Sometimes it may take more than once if you didn’t get it closed evenly the first time.
01-28-2024, 04:44 PM | #6 | |
Rep 7,486
You can see the electrical connection in the upper left in the pic below: And you can also see it in the pic below (its #1):
01-28-2024, 11:28 PM | #9 |
Rep 7,486
When using the online part database sites like bimmercat or realoem.com…make sure that you read the part number index below the diagram for clarification.
Also, when a part is grayed out (like #12 in your diagram) that means that part isn’t used on the vehicle info that you entered. Since there are options and different configurations depending on market…everything illustrated in the diagram may not be used on every vehicle. When I pull up the diagram for the US market (using my VIN)…item #12 is not listed in the part number index. But when I enter data for a Euro market model similar to mine…#12 shows up in the part database and it is listed for a specific option: For vehicles with
01-29-2024, 02:16 PM | #10 |
Rep 37
Qsilver7 I went to take out the old latch to see if I could unplug to have the beep stop until i replace. While taking out the latch I noticed the sensor cable was frayed and stuck in the air duct connector. I replaced my spark plugs and coils a couple days prior and I must of damaged the cable when I was putting things back together again. Nothing a little electrical tape couldn't fix. All is good.
Thanks for your responses! |
JBF650115.50 |
01-30-2024, 05:30 AM | #11 |
Rep 7,486
Wow…glad you found the culprit and was an easy fix. Appreciate the thread update.
